Tech: Setup, Repairs and Mods
Edge problems...
11-07-2005, 05:41 PM
m0p
Posts: 187 - iTrader: (
Edge problems...
The stability problem with my Edge has returned. If I raise or depress the bar even slightly, the guitar will go out of tune, some strings will go out significantly. I have a feeling it could be bad studs, although I fear it may be loose stud anchors loose. Last time I pulled the trem, the studs were loose as hell, and they don't look quite 90 degree to the body, although, I am not sure the set screws are locked, I can't actually seem to lock down the set screws, so it may just be a faulty set of studs. Are there any ways of checking for loose stud anchors without pulling the trem? I've just done a great setup on this thing and don't feel like spoiling it. I'll only know for sure when I get new studs, but I'm slightly concerned though.
m0p
Find all posts by m0p
11-07-2005, 06:05 PM
buddroyce
Posts: 1,914 - iTrader: (
Re: Edge problems...
Double check to make sure that your studs are locked. Usually, your knife edges on yoru trem will wear out before your studs wear out.
I'd take out the studs to makesure that you can actually screw them in and that they are working properly. (using the proper allen key helps too.. double check to see if your key is too small)
buddroyce
Visit buddroyce's homepage!
Find all posts by buddroyce
11-07-2005, 06:13 PM
m0p
I've got the right key for the studs, they screw right in, but I'm not sure I have the correct key for the set screws, the one I have works, but I am not too sure, I can only seem to be able to screw the set screws in, but to remove the key I have to unscrew them again, leaving it unlocked. Hmm.
m0p
11-07-2005, 06:40 PM
ryanb
Posts: 1,457 - iTrader: (
It definitely sounds like your set screw wrench is too small.
ryanb
Find all posts by ryanb
11-07-2005, 06:57 PM
m0p
I'll go out and get my a 1.5mm wrench tomorrow, that's the correct size right? I'll try that, if I still have trouble I'll pull the trem and check if the studs are loose. If they are still loose, I assume it'll be a problem with the anchors? Would it be major work to fix loose anchors?
m0p
11-07-2005, 10:38 PM
ryanb
It depends on how big the problem is. If they are only a little loose, they can usually be glued effectively. [Method 1: run some superglue around them in place. Method 2: pull the anchors out, add wood glue (or epoxy), and reinstall the anchors.] If they have ovalled out a lot of wood, you will have to pull the anchors out, fill the holes, redrill and reinsert the anchors.
BTW: Yes, 1.5mm would be the right size for the stud set screws.
ryanb
11-09-2005, 06:11 AM
m0p
Hmm, if the set screws are indeed unlocked, would there be alot of movement? When I removed the trem a while back, as I said, they were loose as hell.
m0p
11-09-2005, 08:33 PM
ryanb
Maybe. Maybe not. Tighten them up and find out.
ryanb
11-10-2005, 12:44 PM
m0p
Ok, I just attempted to tighten them, but I can't seem to "feel" the set screw, so I'm not sure if I'm tightening it or not.
m0p
11-10-2005, 08:21 PM
m0p
Ok, I finally managed to get these set screws locked. Studs are firm now, minimal to no movement. I think these terrible studs have something todo with it too, there is a nasty groove worn into the cutaway. I haven't loaded the springs back up yet, but I'll do it tomorrow. Too tired to deal with springs* now. Although, one thing that pisses me off is that in order to get the screws to lock, I had to sacrifice my perfect action
08:26 PM
. Reason: argh typo
m0p
will edge zero pro fit edge 3 route?
how to set up a edge 3?
is my edge trem bar in all the way
Edge mysteries solved!!......? - Answers to some common ques
Jason Stone
09:35 AM
Problems with Edge...
Shredcows
10:00 AM
RG520 - Edge tuning problems
RobV
07:21 AM
RG550 and Edge problems with the Edge trem, please advice
LaXu
05:38 PM
Edge and Lo Pro Edge problems after action change - I don't
Kremlin
04:34 AM
03:18 AM
