Tech: Setup, Repairs and Mods
Edge Trem and .10-.52 strings (yes...)
08-05-2003, 12:34 PM
saTa
Posts: 388 - iTrader: (
Heyya... i got a JS90th with an
Edge Bridge
which was blocked until now...
( pic:
http://jazz.strikenet.de/saTa/guitar/js90th/js90_12.jpg
With 8 years of
guitar playing
experience (i'm 17yrs old, btw) i start to get some interest in the tremolo... and since i got a guitar with one of the best trems around why not try it?
now the problem is that i know you should use FOUR springs for 010 strings... apart from the lack of a 4th spring (np, since i will need new ones anyways, i think) i think the strings (D'Addario EXL140) i use may be a problem:
1st e: 010
2nd B: 013
3rd G: 017
4th D: 030 (!)
5th A: 042 (!)
6th E: 052 (!)
i hate 009 stringsets, tho... so i'd rather leave the trem blocked if it's not good to use it with the strings i exclusively use on this guitar...
Long story short: is it possible to use the edge with these trings without major tuning instabilities? what must i do to reach tuning stability with these strings? or shall i just leave it alone and not mess around with it? :P
TIA and sorry for the bad english... i'm german
saTa
Visit saTa's homepage!
Find all posts by saTa
08-05-2003, 12:39 PM
Posts: 19,352 - iTrader: (
You definately want 4 springs with those gauges. You shouldn't have any problems, but you'll have to adjust the
bridge angle
when you do the switch to keep the knives perpendicular
08-05-2003, 12:43 PM
saTa
yeah... i thought i'd have to adjust the angle anyways
thanks, rich
saTa
08-05-2003, 01:13 PM
Texter
Posts: 839 - iTrader: (
Dude if you want to learn how to use a trem start out with a light
string guage
...those will make the trem much lighter to use and allow more nuances...and your saddles wont wear out so that you'll never be able to use them for .009s again...six new saddles will cost you 140 euros...
And you won't be able to tune higher than D with those heavy strings and 3 springs.
Texter
Find all posts by Texter
08-05-2003, 02:02 PM
nuno
Posts: 4,725 - iTrader: (
agree with Texter about string gauge.
anyway, if you cant live without .10s, put 4 springs back there.
nuno
Visit nuno's homepage!
Find all posts by nuno
12-31-2007, 06:26 AM
Scali
Posts: 570 - iTrader: (
Re: Edge Trem and .10-.52 strings (yes...)
How do you put 4 springs in an Edge tremolo?
The base of my LoPro Edge has only 3 holes under that metal bar that holds the springs in place. I believe the Edge is the same.
So where would you attach a 4th spring to the bridge?
Scali
Visit Scali's homepage!
Find all posts by Scali
12-31-2007, 08:47 AM
millzy
Posts: 170 - iTrader: (
i use 9-46 and sometimes a 10-46, but holy god those are some heavy strings, basically your A-string is pretty much the same as my E lolololololol! and i only use 3 springs
millzy
Find all posts by millzy
12-31-2007, 09:47 AM
jazzedout
Posts: 671 - iTrader: (
If you wanted to try the D'addario EXL110 (I think) which are 10 for the high E but 46 for the low E you could use the trem with 3 springs as well. I have been using these for years with no prob. If you want the 52 low E string you'll certainly need to add another spring.
jazzedout
Find all posts by jazzedout
12-31-2007, 11:19 AM
jb4674
Posts: 4,010 - iTrader: (
Reviews: 6
Scali
You take off the little metal cover that holds the springs which is screwed on to the
trem plate
and you will see 2 more holes (the holes where the screws go in). Once you add another spring, you can't use that spring metal cover though.
Jimmy
jb4674
Find all posts by jb4674
01-01-2008, 06:09 PM
LonePhantom
Posts: 5,368 - iTrader: (
Reviews: 98
I've managed to set up 10-52s on an Edge (standard tuning) with 3 springs parallel, and plays great.
LonePhantom
Visit LonePhantom's homepage!
Find all posts by LonePhantom
01-01-2008, 06:12 PM
elcid
Posts: 8,720 - iTrader: (
Dont listen to these little girls telling you to use 9s. Use what you want.
elcid
Find all posts by elcid
01-01-2008, 11:13 PM
ColinMmmmm
Posts: 1,068 - iTrader: (
Agreed. Do it. Four springs are a must though (in my opinion). It's really no problem though.
ColinMmmmm
Find all posts by ColinMmmmm
01-02-2008, 12:55 AM
brothersnowgone
Posts: 1,498 - iTrader: (
Reviews: 7
jb4674
You take off the little metal cover that holds the springs which is screwed on to the trem plate and you will see 2 more holes (the holes where the screws go in). Once you add another spring, you can't use that spring metal cover though.
Jimmy
one screw can hold the spring claw lock on good enough...
And I agree with elcid...
I've had the same setup as Lonephantom, but tuned to drop-c and a .56 on the low-c I think.
brothersnowgone
01-02-2008, 01:28 AM
Axewielder
Posts: 60 - iTrader: (
Anybody ever try drilling the sustain block to add a fourth spring? Sticking the springs in the screw holes seems like a hack to me.
Axewielder
Find all posts by Axewielder
01-02-2008, 02:09 AM
brothersnowgone
Reviews: 7
Axewielder
One screw works plenty fine. To me drilling a whole in your sustain block would be a hack job....
brothersnowgone
addario exl
allen wrench
allen wrenches
bridge angle
edge bridge
edge trem
edge trems
guitar playing
pro edge
string guage
trem block
trem plate
trem springs
how to intonate a zr trem
will edge zero pro fit edge 3 route?
what trem is on the rusty cooley
11:26 PM
