Tech: Setup, Repairs and Mods
Edge Trem problems - wacky scraping sound
07-09-2001, 05:25 AM
DemonicMinor
Posts: 32 - iTrader: (
I have 3 7 strings: an RG7620, UV777BK, and an RG2027. *on both of the RG's the
trem arm
makes a funny grinding/scraping noise when it is rotated in the trem. *how do i fix this? *has anyone else had the same problem?
DemonicMinor
Visit DemonicMinor's homepage!
Find all posts by DemonicMinor
07-09-2001, 05:58 AM
low iq 88
Posts: 20 - iTrader: (
Edge Trem problems
i have the same problem, but since it doesn't go through the amp at all, it doesn't bother me one bit.....i read about a possible fix, just don't remember....and I don't wanna give you false info...so just wait 'till someone gives a better reply
low iq 88
Find all posts by low iq 88
07-09-2001, 06:13 AM
DemonicMinor
Edge Trem problems
haha, yeah it doesn't go through the amp, but since i'm a perfectionist, it bugs the heck outa me! *my RG7620 has taken a lot of abuse over the years, so I'm not too surprised that it's doing weird stuff, but my Prestige is just a few months old, so why is it doing this?? *i tried fixing it with a small file on my RG2027, but all that resulted in was a scratch on the trem's paint :doh:
DemonicMinor
07-09-2001, 06:21 AM
low iq 88
Edge Trem problems
i know how you feel
i guarantee a high percentage of jem/uv owners are of the same mindset
low iq 88
07-09-2001, 06:33 AM
DemonicMinor
Edge Trem problems
oh, after reading various posts on this site, i know that for a fact!
DemonicMinor
07-09-2001, 11:41 AM
Vaibanez
Posts: 814 - iTrader: (
Edge Trem problems
It's most likely the spring that holds the bar in the socket. You can try bending it out a bit to relieve the pressure against the bar and see if that doesn't help.
Or, it could possibly be the socket itself has a bur or other damage on the inside. Click the "Ibanez Rules" banner and talk to Rich. He can get you the sockets and probably has them in stock.
J>
Vaibanez
Find all posts by Vaibanez
07-09-2001, 04:29 PM
DemonicMinor
Edge Trem problems
alrighty thanks, i'll give that a try.
DemonicMinor
07-09-2001, 05:38 PM
DemonicMinor
Edge Trem problems
hmmmm... does that little spring even need to be in there at all?? *I took it out, and the scraping sound is gone, and the trem arm still seems to stay in there just fine, because of the little washer thingies on it. thanx.
DemonicMinor
07-09-2001, 06:03 PM
jemsite
Administrator
Posts: 9,271 - iTrader: (
Edge Trem problems
i don't believe the spring has any use, other than to provide a weakly clip-lock the bar in. The springarm fits where the tip of the
tremolo arm
indents.
if your white bushings are tight, the spring can be removed with no problems. Again the worst that could happen is the arm work it's way out a little bit after alot of use... glen
jemsite
Find all posts by jemsite
07-10-2001, 02:24 AM
DemonicMinor
Edge Trem problems
Hey, thanks a lot for all your help, I bent the spring out a bit and it did the trick! *next stop....new pickups!! :biggrin:
-Bradius
DemonicMinor
trem arm
tremolo arm
how to intonate a zr trem
will edge zero pro fit edge 3 route?
what trem is on the rusty cooley
07:27 AM
