Old 05-30-2006, 08:47 PM
UFORocks  is offline
Posts: 26  -  iTrader: (0)
Edge Trem Question
Is the length of the trem block the only difference between a recessed and non-recessed Edge?
Thanks,
Steve
Old 05-31-2006, 01:18 AM
Ironjose  is offline
Posts: 1,056  -  iTrader: (0)
Re: Edge Trem Question
the recessed and non-recessed is when the tremolo is a floating tremolo or like EHV uses with his guitar when the tremolo dont float, i think the edge pro can be a recessed tremolo (no floating)
JJ
Old 05-31-2006, 03:09 AM
john1880  is offline
Posts: 468  -  iTrader: (1)
steve. i think it is the only difference. the only difference that may matter anyway. a non recessed edge would be from a much older ibanez i would think. i've seen both and they look to have the same design. oh, and the plating may be different too.
john
Old 05-31-2006, 10:04 PM
Ironjose  is offline
john
the plating? what do you mean?
JJ
Old 05-31-2006, 10:05 PM
Dee  is offline
Posts: 8,514  -  iTrader: (2)
I think he means the finish?
Old 06-01-2006, 02:12 AM
john1880  is offline
yes, the finish(a.k.a. plating...the technical term i guess). thanks JJ.
Old 06-01-2006, 11:26 PM
UFORocks  is offline
john
Yeah, thats what I think I too. I bought an edge from a RG550 to put in my roadstar project. Everything seemed to work out fine except that block, unfortunately the longer blocks arent so easy to find, so I ended up routing the rear trem cavity to allow the springs to clear.
Thanks to everyone who responded.
Later,
Steve
Old 06-02-2006, 12:56 AM
Ironjose  is offline
oh you mean the finish, i didnt really understand what were you trying to say... i thought you were saying the plate that holds the saddles.... but no problem anyways...
JJ
floating tremolo, recessed trem, trem block
Question about trem springs 7stringninja Tech: Setup, Repairs and Mods 0 04-17-2006 01:41 PM
chrome lo pro and edge trem satchyvaihalen Classified Ads: Guitars and Gear 2 08-07-2005 04:51 PM
fs cosmo hardware inluding orginal edge trem gunkungfu Classified Ads: Guitars and Gear 4 07-20-2005 01:34 AM
Edge Pro II swap into an Edge Pro trem??? Flame_Virtuoso_6688 Other Ibanez Guitars (including Premiums) 0 07-18-2005 07:01 PM
replacing an edg/lopro trem with the edge pro abstrakt JEM and Universe Guitars 1 09-24-2004 10:50 AM
