Old 12-28-2008, 12:07 AM
Homebake  is offline
Posts: 1,041  -  iTrader: (1)
edge zero and .11s
i use .11-.48 gauge of strings and i have an rg2550z (with edge zero trem obviously).
until yesterday, i dealt with the trem being not quite parallel with the body of the guitar. the tremolo block in the back was as far back as it could be while still touching the stop rod in the back. the thing is, if you want the bridge to be parallel with the guitar with an edge zero with .11s it seems, it won't be touching the stop rod, therefore rendering the zero system pretty much useless.
so, i wrapped some tape over the bar to add about half a centimetre of thickness to the rod. i adjusted the tension so the bridge was parallel to the body. obviously, without the tape it wouldn't be touching the bar, but now with the tape, it was effectively how it should be.
i've been considering dropping down to .10s because of this, i think i might. i wonder if ibanez will ever fix this? or am i missing something huge...
anyway, quick fix for anyone with the same problem.
Old 12-28-2008, 12:17 AM
Rich  is online
Posts: 19,348  -  iTrader: (21)
Re: edge zero and .11s
The Egen springs are heavier, whenever they become available.
Old 12-28-2008, 02:07 AM
Homebake  is offline
where would i be able to get some, when they're available? you?
Old 12-28-2008, 02:10 AM
Rich  is online
Sooner or later. I'm still trying to get regular ZR springs.
Old 12-28-2008, 04:42 AM
RSVampire  is offline
Posts: 1,813  -  iTrader: (6)
is that the Edge Zero or the Zero Resistance trem?
Old 12-28-2008, 04:47 AM
Homebake  is offline
that's the edge zero trem with the ZPS3 bar, on an RG2550Z. it's a knife edge, the difference with a zero resistance is that it's a ball bearing system i think?
11s, edge zero, guage, rg2550z
Can you replace an edge trem with a LoPro Edge? - Is it poss Cycovision Tech: Setup, Repairs and Mods 7 05-16-2009 01:22 AM
Replace Edge Pro With Edge/ Lo-pro Edge Trem Vaistarr Tech: Setup, Repairs and Mods 28 04-01-2008 01:18 PM
WTB: Edge Pro Tremolo or Trade for mint Original Edge For_The_Love_Of_Jems Classified Ads: Guitars and Gear 3 02-12-2008 02:24 AM
Edge bridge repairs - post & knife edge jd Tech: Setup, Repairs and Mods 6 12-09-2002 06:48 PM
RG550 and Edge problems with the Edge trem, please advice LaXu Tech: Setup, Repairs and Mods 7 08-13-2002 05:38 PM
