Re: Edge Zero doesn't divebomb all the way.
That's strange. Assuming you set everything up when you put the 10's on it correctly, it should still allow you to go slack. If you didn't set it up properly, and the tension of the 10's pulls your trem forward slightly, I could see the possibility that the strings would never go totally slack when dive-bombed...
