First, this is the first floating bridge guitar I've owned, so I decided to do some research on setup. Came across the ibanezrules tech setup page...
on that page, it says there are set screws in the post that need to be loosened to make action adjustments. Is this for the original edge and lo-pro only, or does this apply to the
Edge Zero as well. I have not seen these set screws in the posts, but figured it's safer to ask first
