Old 02-04-2008, 05:48 AM
brianxtr  is offline
Posts: 1,641  -  iTrader: (8)
Re: Edge3 Replacement Tremolo
hello
i have here a ibanez proline/rg with a floyd rose ll ,i think all original(the first owner couln't chance the trem(not even the strings hahaha (joke)look at the picture.
http://img180.imageshack.us/my.php?i...oydrosexv3.jpg
Old 02-04-2008, 06:43 AM
pera_a777  is offline
Posts: 406  -  iTrader: (0)
So, edge pro then..?
Old 02-25-2008, 05:13 AM
Wolfram  is offline
Posts: 910  -  iTrader: (0)
Reviews: 12
I have a 2002 RG370 will an Edge Pro, Edge III or Edge Pro II fit? This is all doing my head in!
-Wolfram
Old 02-25-2008, 07:02 AM
Crazy_Guitar  is offline
Posts: 1,319  -  iTrader: (0)
Reviews: 4
Will it add anything up to this discussion if I say that I fitted my RG470 with an OFR Pro?...
Old 02-29-2008, 10:45 PM
ChaosAndOrder30  is offline
Posts: 17  -  iTrader: (0)
So can you retrofit a lo-pro into an edge pro route if you sand down the wings about an 1/8 of an inch? of will the tail of the trem be a problem also?
Old 03-07-2008, 05:48 AM
85db  is offline
Posts: 2  -  iTrader: (0)
-Wolfram
My head is spinning too... My take-away from all this is that the Edge Pro is a direct replacement for the Edge III in all those cheap RG models like RG350.
Old 04-16-2008, 02:53 PM
FoneBone  is offline
Posts: 4  -  iTrader: (0)
I've got another combination:
I've bought an older RG body, which has the routing for an edge or lo-pro edge. Now my question is: Will an edge pro II retrofit this routing?
Btw. the body hasn't arrived yet ;-)
Thx
FoneBone
Old 04-18-2008, 11:52 AM
FoneBone  is offline
Thx
FoneBone
It DOESN'T retrofit!!!!
Old 07-20-2008, 12:48 PM
Deepsquirrel  is offline
Posts: 7  -  iTrader: (0)
So choices to replace an Edge III are either an Edge Pro or an OFR?
Would be nice to know before forking out for a replacement bridge.
Old 07-20-2008, 10:52 PM
Ryan350DX  is offline
Posts: 179  -  iTrader: (0)
Deep, The Edge Pro doesn't retrofit the Edge III cavity, your best bet is the Original Floyd Rose.
Old 07-20-2008, 11:48 PM
LonePhantom  is offline
Posts: 5,365  -  iTrader: (6)
Reviews: 98
That's interesting, a number of people have said that the Edge Pro DID fit the Edge III cavity.
Old 07-21-2008, 04:56 AM
nuno  is offline
Posts: 4,725  -  iTrader: (0)
the EdgePro DOES retrofit the Edge-III:
while the Floyd Rose (and Schaller Floyd as well) does NOT retrofit:
(check the wrong knife-to-post relationship)
Old 07-21-2008, 05:11 AM
nuno  is offline
i had the chance to make some trem-to-cavity fitting experiment lately and i ended up with the following results:
on IBANEZ EDGE-III cavity:
• Ibanez Edge into Edge-III cavity: NO
• Ibanez Lo-Pro Edge into Edge-III cavity: NO
• Ibanez Edge-Pro into Edge-III cavity: YES
• Original Floyd Rose into Edge-III cavity: YES
• Schaller Floyd Rose into Edge-III cavity: NO
on IBANEZ EDGE/LoPro EDGE cavity:
• Original Floyd Rose into Ibanez Edge/LoPro Edge cavity: YES
• Ibanez Edge-Pro into Ibanez Edge/LoPro Edge cavity: YES
on IBANEZ EDGE-PRO/EDGE-PRO II cavity:
• Ibanez Edge into Ibanez Edge-Pro/Edge-Pro II cavity: NO
• Ibanez Lo-Pro Edge into Ibanez Edge-Pro/Edge-Pro II cavity: NO
• Original Floyd Rose into Ibanez Edge-Pro/Edge-Pro II cavity: YES
• Schaller Floyd Rose into Ibanez Edge-Pro/Edge-Pro II cavity: NO
on Original FLOYD ROSE cavity:
• Ibanez Edge into Original Floyd Rose cavity: YES
• Ibanez Lo-Pro Edge into Original Floyd Rose cavity: YES
check pics HERE. sorry, italian only, but pics pretty much explain themselves
*EDIT*
gotta update the above compatibility list as to avoid readers to take wrong references.
*EDIT 2*
converted aspx to html
Last edited by nuno; 12-12-2008 at 04:24 AM. Reason: references updating + aspx to html conversion
Old 07-21-2008, 11:20 AM
Has the Edge III cavity changed over the years? or has it remainded the same?
Old 07-21-2008, 06:42 PM
I won't be needed to put a new tremolo in after all
Managed to get a preowned Prestige RG1570 (edge pro already in there obviously) for £215, only around £50 more than i would have ended up paying for an OFR or an edge pro anyway! (replacement stuff is more expensive over here)
base plate, floyd rose, floyd rose pro, ibanez dealer, lopro trem, neck shim, pro edge, schaller trem, string lock
I need to find replacement tremolo studs for a Lo-TRS II, help! arilr Other Ibanez Guitars (including Premiums) 2 07-30-2006 07:48 PM
Broken ZR tremolo... Is this common?? FastRedPonyCar Other Ibanez Guitars (including Premiums) 16 06-01-2006 05:50 PM
S470DX, broken tremolo :( Steve069 Other Ibanez Guitars (including Premiums) 10 05-16-2006 04:50 PM
Just a question... - about Tremolo Bridge Height Adjustment armindo__dias Tech: Setup, Repairs and Mods 2 11-03-2001 01:20 AM
Lo-pro Edge tremolo - replacement for 555 kylemac Gear and Equipment 7 07-24-2001 07:41 PM
