Tech: Setup, Repairs and Mods
Edge3 Replacement Tremolo
Page 6 of 18
02-12-2009, 08:24 PM
madpickin03
Posts: 531 - iTrader: (
Re: Edge3 Replacement Tremolo
You should be able to pull em out. Here's what it looks like when taken out
I think you have to use 2 hammers/pliers for this.
madpickin03
Visit madpickin03's homepage!
Find all posts by madpickin03
77
02-13-2009, 05:56 AM
ibz_SA
Posts: 913 - iTrader: (
The most important and useful thread on jemsite I have seen in awhile should be stickied or edleast book marked :P
ibz_SA
Find all posts by ibz_SA
78
02-13-2009, 08:09 AM
nuno
Posts: 4,725 - iTrader: (
LonePhantom
...but someone like Nuno should be able to give you a more concrete answer.
hehe, i actually PM'd with Blaireau about this, and i told him i usually pull that plate out just with a knife wedged right underneath. don't know if it's a "professional" fashion, but it works.
nuno
Visit nuno's homepage!
Find all posts by nuno
79
02-13-2009, 04:16 PM
Yanic
Posts: 32 - iTrader: (
I am gonna exchange my Edge 3 with an OFR, and I would like to know if I HAVE TO remove this anchor thingy or can I just put the new studs in ??? Or do I have the same problem as blaireau has?
Yanic
Find all posts by Yanic
80
02-13-2009, 05:03 PM
jim777
Posts: 8,943 - iTrader: (
Moved and stickied
jim777
Find all posts by jim777
81
02-13-2009, 07:03 PM
chrisgr
Posts: 54 - iTrader: (
Yanic
The OFR studs are a larger diameter so they will not fit into the edge III anchors. You have to pull the edge III anchors, drill the existing hole out to accomodate the ofr anchors.
chrisgr
Find all posts by chrisgr
82
02-16-2009, 01:14 PM
Yanic
And what about the routing? We know that the OFR fits but what about up bendings? The cavity is only about 1.5 cm deep under the backpart of the Vibrato (that`s about 0.59" I think). So should I make it deeper?
Yanic
83
02-21-2009, 05:30 PM
blaireau189
Posts: 4 - iTrader: (
Yanic
@Yanic: nuno's pics earlier in this thread suggest that upbendings should be no problem with an OFR in an Edge III cavity. At any rate, I wouldn't route anything before I hold the thing in my hands and see whether there is actually a problem.
Has anyone experience with drilling out the Edge III anchor holes to fit in the larger Edge Pro inserts? I'd like to know how risky this business is, before I decide whether I want to try it. What diameter should the holes be, so that the new inserts fit tightly? Many thanks!
blaireau189
Find all posts by blaireau189
84
04-09-2009, 08:23 PM
nsabino
Posts: 463 - iTrader: (
Hi, I'm wondering if anyone has spray painted and edge tremolo? Just wondering if it's worth it or not?
Regards,
Nelson
nsabino
Find all posts by nsabino
85
04-21-2009, 09:46 PM
JEMINIxLEGACY
Posts: 3 - iTrader: (
I don't understand does the Gotoh retro fit or not?
JEMINIxLEGACY
Find all posts by JEMINIxLEGACY
86
04-27-2009, 10:22 AM
toshiro
Posts: 1,811 - iTrader: (
The Gotoh and an Original
Floyd Rose
have a similar footprint. The bass side "wing" is sightly bigger on the Gotoh, and both "wings" are slightly longer.
I had to dremel out a small amount of wood from my 2009 XPT700 to get an OFR into it. The problem was on the treble side wing.
Photo of the bridge in the reshaped rout here:
http://img.photobucket.com/albums/v4...ebDSCF0678.jpg
It would probably take less wood to get the Gotoh in, but in a different spot.
12:17 PM
toshiro
Visit toshiro's homepage!
Find all posts by toshiro
87
05-18-2009, 06:44 PM
mxr2000
Posts: 17 - iTrader: (
Hi all i was looking for a good floyd style replacement, for a Ibanez using Edge III tremolo bridge which i don't like at all. this Bridge can be replace with a old lo edge pro from the older models without any mod? the edge III is on a RGT42DX any sugestion are welcome..
mxr2000
Find all posts by mxr2000
88
06-09-2009, 09:41 PM
Vikingguitar
Posts: 75 - iTrader: (
I know thatthe edge 3 can be swapped for an ofr or an edge pro. I have an ibanez rgt42 with edge and i set up it well, it stays in tune and i can do some cool stuff with it, the problem y durability and the arm, i have used teflon tape and varnish but it becomes thin after 2 months. My only option is an Ofr since I live in Mexico and edge pro is not available here, I think that an OFR can be chipped with warmoth or beyond eleven or other store, but I dont know if there will be problems with the radius and the nut. If i can get the fr nut to work and the bridge without having to buy tons of shims and to correct crazy radiuses i'll buy it. Tell me please if it can be done or I better stick with my edge 3.
Maybe Nuno could help
09:42 PM
. Reason: Incomplete message
Vikingguitar
Find all posts by Vikingguitar
89
06-13-2009, 06:31 AM
Vikingguitar
I've been doing my homework and came with the next:
After asking a youtube guy that did edge 3 to OFR he told me that neither R2, R3 or R4 work, radius make the strings too high.
Either a toplok 3 (i dont know what this is, maybe an older ibanez nut, maybe edge 3 nut) or a gotoh 43 mm could work. Assuming he told me toplok, I might expect the nut is top mounted, not rear mounted, correct me if I'm wrong,
About shims, I do not want to to spend months and a fortune buying them, i do not know the shape but if someone can help it could save me some weekends.
I saw a Floyd Rose nut that appears to be 1-11/16 with a 15 radius (i think this is close to the ibanez 16 radius neck , although im not sure it is 16, im new to all this info)maybe this one could fit without much hassle.
Finaly I saw another nut in the same site 1-11/16 but claims to be without radius, do not know the meaning, maybe to customize it, or simply radius-less and totally flat to stay like that.
Sorry for the long post, its just a lot of questions and wish for answers. If you can help I will appreciate it. Everything in a nutshell would be :
Which nut works, 15 radius, no radius, gotoh 43 mm, leave current one or some ibanez nut from Rich? (If posible, how to modify R4, which is radius 10, to work properly)
Help me designing shims tell me basic shape or make a drwing (raw and no detalied accepted)
I leave you the sites
Beyond eleven (for OFR nuts)
Guitar parts depot (for gotoh)
Regards from Mexico
Vikingguitar
90
06-13-2009, 09:10 AM
toshiro
I would leave the stock one on there before swapping to a 10" radius OFR nut, in fact I still have an Edge III nut on my OFR'd Xiphos.
Ibanez's Top Lok III is the Edge/LoPro Edge Locking nut used from the 80's until the Edge-Pro era. It mounts from the rear, and should work. Gotoh's 43mm rear-mount nut is the exact same thing as a Top Lok III, the cardboard on the packaging is the only difference.
toshiro
Page 6 of 18
base plate
floyd rose
floyd rose pro
ibanez dealer
lopro trem
neck shim
pro edge
schaller trem
string lock
how to measure tremolo to scale
edge pro stud replacement?
how to use zr tremolo?
is the edge zero tremolo a good tremolo
I need to find replacement tremolo studs for a Lo-TRS II, help!
arilr
07:48 PM
Broken ZR tremolo... Is this common??
FastRedPonyCar
05:50 PM
S470DX, broken tremolo :(
Steve069
04:50 PM
Just a question... - about Tremolo Bridge Height Adjustment
armindo__dias
01:20 AM
Lo-pro Edge tremolo - replacement for 555
kylemac
Gear and Equipment
07:41 PM
01:29 AM
