Old 12-16-2009, 04:54 AM
dimitar  is offline
Posts: 487  -  iTrader: (1)
Re: Edge3 Replacement Tremolo
Guys, I want to replace my oridinal EDGE with LO-Pro Edge.
It is possible ?
Thank!
Old 12-16-2009, 05:08 AM
Brambram  is offline
Posts: 407  -  iTrader: (0)
Yes, the Edge and Lo Pro Edge are completely interchangeable.
Old 12-16-2009, 05:10 AM
dimitar  is offline
Thanks man!
Old 12-17-2009, 01:48 PM
gto6412  is offline
Posts: 1  -  iTrader: (0)
Thumbs up
My OFR on my Ibanez RG 5EX1 :-)
Old 01-10-2010, 04:06 PM
nasticanasta  is offline
Posts: 40  -  iTrader: (0)
Images: 2
Personally I don't understand what all the crying is about, I have an RG4EX1 (edge III) and it stays in tune perfectly. I'm assuming your edge III isn't set up right, people tend to set the edge III base plate level with the body of the guitar which is incorrect, as for the knife edges..... petroleum jelly from the get go.
Old 01-10-2010, 05:16 PM
SilverEra  is offline
Posts: 340  -  iTrader: (0)
Reviews: 4
No, they suck even when set up correctly I've had three, they all gave out after a few months. One did something along the lines of what happened to this one;
Old 01-10-2010, 06:21 PM
Mr. Killer  is offline
Posts: 401  -  iTrader: (0)
I've only had very minor problems with my Edge III, but for the price they're a good choice I think.
Old 01-16-2010, 03:24 PM
Jason1635  is offline
Posts: 14  -  iTrader: (0)
Some Pics from my RG350DX OFR upgrade
OFR from 169.00
shipping about 10.00
Rock solid, beat the hell out of it and it still stays in tune.... Priceless
37mm block came with the OFR, fits fine, I think the 42 would have fit also
Make sure it says "Made in Germany"
The OFR studs screwed right into the existing inserts, lined up perfectly
The right side is close but it doesn't hit in any way
Small gap on left side but strings line up perfectly
Finally set up, thank god, quite the pain
End product, I'm loving the "FRED" in the bridge too
I've heard that the tolerances are not really that tight in the manufacturing process but in my particular guitar, the studs were spaced absolutely perfect and the cavity accomodated the OFR nicely. All in all, a pretty easy upgrade. Hope this helps anyone considering this.
Oh and the R9 nut is what I put on.
Old 01-19-2010, 05:55 PM
Scali  is offline
Posts: 570  -  iTrader: (0)
Not *entirely*. On all recent production guitars, they should be interchangeable yes... However, there is one difference: The LoPro Edge NEEDS a trem cavity, because the finetuning mechanisms are mounted below the baseplate.
The original Edge can also sit on top of the body, just like the OFR.
Certain older Ibanez guitars have an Edge 'on top', and a LoPro Edge won't fit, as the finetuners would touch the body.
Here's an example of such guitars:
Old 01-19-2010, 06:06 PM
jono  is offline
Posts: 5,003  -  iTrader: (2)
Thumbs up
Well spotted, that man!!!
Prhaps a techncality, but a very important one if you've got one of the older guitars in question!!!
Old 02-07-2010, 10:27 PM
danlee0502  is offline
Posts: 15  -  iTrader: (0)
What bridge did u have b4 u replaced it? I'm trying to look for any easy replacement with locking studs for my edge pro. Gahh soo much to readd XD
Old 02-23-2010, 10:44 PM
SomeonesGottaBeSaneDonnie  is offline
Posts: 10  -  iTrader: (0)
I can't believe so many don't like the Edge III.
I love mine!!!
Stays in tune FOREVER despite the fact that I beat the living daylights out of the strings and use the bar QUITE often.
Maybe I got a good one or something???
Old 02-24-2010, 12:34 AM
LonePhantom  is offline
Posts: 5,368  -  iTrader: (6)
Reviews: 98
Gotoh licensed Floyd Rose comes with locking studs, but you don't need to go that far. Check out Ibanez Rules (banner up top). I believe the locking studs for the Edge/Lo Pro Edge work for the Edge Pro. Ibanez Rules should have some, or be able to get some. I'd verify my statements with Rich though. It's been a while since I remember reading about it, and may have me facts not quite right.
Old 03-27-2010, 05:59 PM
poonmaster  is offline
Posts: 7  -  iTrader: (0)
I just finished a 320 where i replaced everything but the body. I had an old kramer striker with an ofr i put in , yes it will fit with some routing, but the block of the trem sticks out of the body to make contact with you to just it make impossible to keep in tune or hell you cant put the cover on. i need another edge 3 if anyone has one for sale, and i guess i got a black ofr forsale myself.
Old 04-12-2010, 12:00 PM
Kont De La Fere  is offline
I have no good experiences with Edge 3 tremolos You're lucky if yours keep the tuning when abused.
base plate, floyd rose, floyd rose pro, ibanez dealer, lopro trem, neck shim, pro edge, schaller trem, string lock
I need to find replacement tremolo studs for a Lo-TRS II, help! arilr Other Ibanez Guitars (including Premiums) 2 07-30-2006 07:48 PM
Broken ZR tremolo... Is this common?? FastRedPonyCar Other Ibanez Guitars (including Premiums) 16 06-01-2006 05:50 PM
S470DX, broken tremolo :( Steve069 Other Ibanez Guitars (including Premiums) 10 05-16-2006 04:50 PM
Just a question... - about Tremolo Bridge Height Adjustment armindo__dias Tech: Setup, Repairs and Mods 2 11-03-2001 01:20 AM
Lo-pro Edge tremolo - replacement for 555 kylemac Gear and Equipment 7 07-24-2001 07:41 PM
