Old 11-01-2004, 03:46 PM
nukem2k5  is offline
Posts: 26  -  iTrader: (0)
EL-34 power tubes. Recommendations please?
I'm going to replace the power tubes in my Marshall JCM-2000 DSL 100w and would like some suggestions on what brand tubes to buy.
Also, I intend to buy a multimeter and bias the amp myself so if any of you have a link to a guide or feel like explaining it to me, please do so. I believe the setting for the JCM2000 dsl 100w is -90 mV but I'll definitely confirm that before I do it.
Old 11-01-2004, 04:13 PM
power freak  is offline
Posts: 395  -  iTrader: (0)
What tubes you choose depends on your playing style and tone really. If you give us a hint at what tone you want it may be easier to suggeest tubes.
Biasing a DSL or TSL:
There is a thing labelled "CON5" on my 401, although I think on some it may be callled a something different. Its simply three connectors, they are straight long pole type things (sorry I am bad at explanation) the centre one is ground and the outer two are positive for your multi meter! Simply adjust the trimmer "PR1" until you hit the values: (Caution go slowly! The adjustment is very sensitive!)
DSL50 45mV
TSL60/1/2 80mV
DSL100 90mV
DSL401 1.375V
TSL100/122 90mV
DSL201 .675V
(others added for others that may need it.)
pretty simple huh!
Regards
Old 11-01-2004, 05:53 PM
nukem2k5  is offline
I'm not really sure what kind of tone I'm looking for. I like to play metallica and iron maiden sort of stuff and I like to shred but I'm interested in studying some more melodic ways to play like vai and satriani.
If you can give me any advice I'd appreciate it.
Old 11-02-2004, 03:22 PM
nukem2k5  is offline
I hear the Svetlana tubes are really good. Anybody have any experience with the EL34 Svetlana's?
Thanks.
Old 11-02-2004, 03:32 PM
I guess you would want medium to slow break up, yes? Since with metal type tones most gain is in the pre-amp. However you will want some break-up because Vai has a bit of break up going on.
In that case I would reccomend a Svetlana, since they are a bit slower at breaking up compared to say a Chinese type tube. They have a slightly rolled off top which may or may not be desireable for you. A sovtek WXT would also be a great choice, but doesn't have as much high end roll off and is not as "clear" sounding and the break up is more aggressive than smooth.
Old 11-02-2004, 05:26 PM
nukem2k5  is offline
What exactly is a slow break up? I mainly want something that sounds good clean at high volumes and has some good, thick distortion and tone.
Old 11-02-2004, 05:53 PM
Power tube break up is when the amp is totally cranked, and even with low pre-amp gain you still get some distortion. Its "creamy" aounding and is visible on some of the earlier van halen records. A slow break-up reduces this effect. If you by groove tube rated tubes they have a rating system of 1-10 to choose break volume. I believe 1 is hard breaking and 10 is fast breaking up. Although I have never bought GTs so I am not sure.
Old 11-03-2004, 01:18 AM
nukem2k5  is offline
When do people usually prefer a fast breakup? I mostly play distortion (via amp distortion or pedals/effects) but I like my clean to sound good when it's cranked.
amp distortion, iron maiden, van halen
