Old 12-16-2000, 12:33 PM
Andy J Dampier  is offline
Location: Ft Lauderdale-Fl....oh man...women...women...women...
Posts: 146  -  iTrader: (0)
Exposed Coil Humbucker's - How would this sound on my FP?
Just for shats and giggles, I was wondering if anyone has ever tried taking that ribbon off the pick-ups, to expose the coils. I know Gisbon does this with their Gothic series guitars, and it says it gives the guitars a wicked sound...so even though they are probably just blowing smoke up their own asses, has anyone ever tried this?
Thanks!
Old 12-16-2000, 03:23 PM
Vaibanez  is offline
Posts: 813  -  iTrader: (5)
I don't think the ribbons do anything but hide the copper windings. It's purley cosmetic. It's just a strip of nylon glued to the pickup. If you want to expose your windings:biggrin:, I won't look.....hehehe.
J>
Old 12-18-2000, 03:22 PM
wyldbill  is offline
Posts: 190  -  iTrader: (0)
Actually, it probably protects the windings as well. AFAIK, pup winding is usually done w/ wire coated w/ laquer or shellac, anyway, some thin, fragile substance with a high dialectric constant as an insulator. The benefit is that the insulation is thin, so you can pack more winding in the same space for a hotter pup (same is true for transformers and motor windings). BUT, if you chip it *(the insulation) you'll get shorts and you're off to buy a new pup.
FWIW,
-bill
Old 12-18-2000, 05:04 PM
darren wilson  is offline
Posts: 4,190  -  iTrader: (0)
Gibson writes:
“Exposed coil pickups ensure an equally wicked sound.”
I think they're referring to the fact that these pickups don't have Gibson's customary nickel covers over the bobbins.
They should have written “exposed bobbin pickups.” I don't think they're saying that they've removed the protective ribbon from the actual coil windings.
As wyldbill suggested, that'd be rather foolish.
coil pickup
