Old 04-05-2001, 10:23 AM
cowcowcow  is offline
Posts: 289  -  iTrader: (0)
F Space - Why single coil don't need?
Why Single coil pickup don't available as "F-Space"?
Old 04-05-2001, 12:39 PM
darren wilson  is offline
Posts: 4,190  -  iTrader: (0)
F Space
Single coils are already F-spaced by default. "F-spaced" means either Fender-spaced or Floyd-spaced, depending on whom you talk to.
Humbucking pickups were designed and for years used exclusively only on Gibson guitars, which have narrower string spacing than Fender's offerings. Fender designed their single-coil pickups for their own guitars' string spacing.
When guitarists started installing humbuckers in Strat-style guitars, it became apparent that the magnetic field of Gibson-spaced humbuckers wouldn't completely cover the string width of a Fender-style bridge/neck.
Most players just lived with it, but Edward Van Halen compensated for the narrower spacing by rotating the pickup on a slight angle in order to widen the spread of the magnetic field by extending the "corners" out slightly. Years later, DiMarzio brought out their F-spaced humbuckers and Duncan started making Trembuckers.
Old 04-05-2001, 01:28 PM
F Space
Oh I SEE
Thanks
Old 04-05-2001, 09:44 PM
jem7pbk  is offline
Posts: 208  -  iTrader: (1)
F Space
so if I want to put a dimarzio or duncan humbuker in one of my Ibanez's I have to get f spaced humbuckers or a duncan trembucker? then a regular duncan jb wont work in my jem?
Old 04-05-2001, 10:29 PM
Vaibanez  is offline
Posts: 814  -  iTrader: (5)
F Space
I'm pretty sure the JB comes in an "f" spaced model.
J>
Old 04-05-2001, 11:25 PM
F Space
"Trembucker" now seems to be Duncan's term for "F-spaced".
It started with their "parallel axis trembucker" which had those double rectangular pole pieces on either side of each string, and was the first humbucker Duncan made with Floyd/Fender spacing.
Old 04-06-2001, 10:32 PM
J Todd Beachler  is offline
Posts: 248  -  iTrader: (0)
F Space
Alright then, smartypantses, riddle me this: *Why aren't the Dimarzio 7-string pickups F-spaced? *
Old 04-06-2001, 11:41 PM
Vaibanez  is offline
F Space
I'm guessing here, but Ibanez used the Gibson spacing to keep the width of the neck down?
J>
Old 04-07-2001, 01:36 AM
RSVampire  is offline
Posts: 1,813  -  iTrader: (6)
F Space
don't know if it's Gibson spacing or not. But the strings are spaced closer together to keep the witdh of the neck down yes. So if it WAS F-Spaced.....the neck would be SO wide.
coil pickup, humbucking pickup, string pickup, string pickups, van halen
