Tech: Setup, Repairs and Mods
f-spaced or regular?
02-08-2009, 12:29 AM
kshands
Posts: 241 - iTrader: (
Reviews: 4
I have a Ibanez RG3EX1 and ive changed the pickups too a DiMarzio X2N in the bridge and a Bill Lawrence USA 500XL in the neck. I dont know what the
spacing
cause theyre are blades instead of hex screws, flat head screws, or phillips head screws. I think the BL500XL is fspaced and the X2N is
regular
(i heard some where that all X2Ns are fspaced) and i dont know why theyre different they just are. It has a fixed bridge, not a trem, it is 25.5 scale. What spacing is it?
I have a 1993 Jackson Stealth HX PROFESSIONAL with a stop tail with a string thru body, like a Dean Razorback DB without that v shaped thing. What spacing is it?
Please help!!!!!!
kshands
Visit kshands's homepage!
Find all posts by kshands
02-08-2009, 12:33 AM
kotornut
Posts: 1,847 - iTrader: (
Re: f-spaced or regular?
search function is there.
kotornut
Visit kotornut's homepage!
Find all posts by kotornut
02-08-2009, 01:46 AM
elcid
Posts: 8,718 - iTrader: (
elcid
Find all posts by elcid
02-08-2009, 02:10 AM
mike570
Posts: 2,205 - iTrader: (
Reviews: 18
elcid
LMAO!!!!
WE need a FAQ section.
Or maybe I should have used the search function to find the "FAQ" section.
OK. I'll answer...
The X2N and BL 500 are both wide rail magnet pickups. As such, they work for both standard and
f-spaced
. There are no poles so no need to worry about spacing.
A fairly good explanation of pickups can be found, quite easily, here:
http://en.wikipedia.org/wiki/Pickup_(music
Cheers!
02:25 AM
mike570
Visit mike570's homepage!
Find all posts by mike570
02-08-2009, 10:25 AM
kshands
Reviews: 4
I know they are rails but im looking to upgrade the pickups in both of my guitars. I need to know what spacing though.
kshands
02-08-2009, 10:37 AM
Algiman
Posts: 2,552 - iTrader: (
Jeese, you'd think that a website like Dimarzio's own might see fit to have a FAQ on the sublect, that was something along the lines of:
the dimarzio website
How do I know which spacing to use?
F-spaced pickups measure 2.01" (51 mm) center-to-center from the first polepiece to the sixth. Standard-spaced pickups measure 1.90" (48 mm). Although some players believe that F-spaced pickups are only for the bridge position of tremolo bridge guitars, many guitars with fixed bridges (including late 1990s Gibson Les Pauls and Epiphone LPs) should have F-spaced pickups in the bridge position. Most tremolo equipped guitars that have a nut width of 1-11/16” (43mm) or more should also use an F-spaced pickup in the neck position. If you’re replacing a bridge-position pickup and you're not sure what your string-spacing is, it's usually better to get an F-spaced model. It is not necessary for the strings to pass exactly over the center of the polepieces for best performance, but it is wise to avoid a situation where the E strings are sitting completely outside of the outer polepieces.
That would be really useful. Oh look, they do.
Not to be an ass kshands, but this info isn't exactly hard to search for.
Algiman
Find all posts by Algiman
02-08-2009, 10:41 AM
EvoGiant
Posts: 355 - iTrader: (
kshands
he just told you that BECAUSE they are rails, spacing doesnt matter...if you are gonna replace the dean pups with rails, then it doesnt matter..or like dimarzio says, if you're not sure, get f-spaced pickups just to be safe..
EvoGiant
Find all posts by EvoGiant
02-08-2009, 12:07 PM
kshands
Reviews: 4
EvoGiant
I know spacing doesn't matter with rails. Im planning on putting a paf pro in the neck and a fred in the bridge of my ibanez/
I dont have a dean, they suck, its a
jackson
stealth hx. im planning on putting a paf pro in the neck, a fred in the middle, and a evo in the bridge. and yes its a 3 humbucker guitar.
Im stupid when it comes to stuff like this.
kshands
02-08-2009, 01:28 PM
mike570
Reviews: 18
mike570
02-08-2009, 01:36 PM
Ibanized
Posts: 422 - iTrader: (
f spaced neck can be regular but f spaced is also okay
Ibanized
Find all posts by Ibanized
02-08-2009, 02:51 PM
mrjakob69
Posts: 448 - iTrader: (
kshands
I dont have a dean, they suck, its a jackson stealth hx. im planning on putting a paf pro in the neck, a fred in the middle, and a evo in the bridge. and yes its a 3 humbucker guitar.
hes from Georgia give him a break.
mrjakob69
Find all posts by mrjakob69
02-08-2009, 04:04 PM
kshands
Reviews: 4
Yea i know and your from the land of rednecks and retards
kshands
02-08-2009, 04:09 PM
Algiman
kshands
It's "you're" not "your", and "i" should have been a capital.
Here ends this grammar police announcement.
The moral of the story is: Learn to do some research before asking questions, then insulting people.
Algiman
02-08-2009, 04:55 PM
elcid
Algiman
That just wouldn't be the new guy to jemsite way.
elcid
f-spaced
ibanez
jackson
regular
spacing
F-spaced what does this mean
F spacing or regular how tell
do i get f spaced for js100
what is f spaced
do single coils come in f spaced?
FS: Pink Dimarzios - Air Clasic Bridge(F-spaced) & Air Classic Neck(reg-spaced)
For_The_Love_Of_Jems
04:47 PM
dimarzio pups, regular or with f-spaced?
son_of_zion
Pickups & wiring
07:40 PM
Will I need F Spaced/Trembucker spaced PU's for my RGA121??
mityjoeyoungxnj
02:01 AM
Regular Wiring
RSVampire
Pickups & wiring
08:13 PM
JEM7DBK pickup - f-spaced or non f-spaced
AvY
10:52 AM
03:05 PM
