Tech: Setup, Repairs and Mods
Feel of LoPro Edge 7 vs LoPro Edge 6 and other setup issues
04-15-2003, 02:43 PM
mdrobnak_rg7
Posts: 5 - iTrader: (
Question:
Is it just that my setup is incorrect, or does a LoPro Edge 7 feel really different than the six string version? I remember when a friend of mine has a
Petrucci model
, the bridge moved so easily and smoothly...Mine does NOT at all...I also have this sorta 'clunka-clunka' sound near the floating point of the bridge..can't really do subtle things..
Re: bridge height...the posts on both side should be at exactly the same height correct?
Re:
bridge angle
...Realistically where should I set it? I can either get it so that dive bombing is easy, but it dumps all really quick..Or I can get it to where I can pull up a bit, but it frets out at the end of travel...
Suggestions please!
If I cant get this to work with a nice new set of strings, and some patience, I'm giving up on this, and bringing it somewhere.
Help Please. :-/
-Matt
mdrobnak_rg7
Find all posts by mdrobnak_rg7
04-15-2003, 06:16 PM
Drew
Posts: 4,538 - iTrader: (
For the clunking noise, check the tightness of the
arm holder
, and then replace the hite nylon bushings. One of those two oughta do it.
Due to the added
string tension
of the low B, a LopPro 6 will definately feel looser than a 7.
-Drew
Drew
Visit Drew's homepage!
Find all posts by Drew
04-15-2003, 06:38 PM
Jeff
Posts: 1,501 - iTrader: (
Is there any way to remove that clunking you get with no bushings on? (for sloppy bar play)
Jeff
Visit Jeff's homepage!
Find all posts by Jeff
04-15-2003, 08:34 PM
steve
Posts: 590 - iTrader: (
No bushings will put it directly metal-to-metal, a fine recipe for even more clunking.
I'd have to say that's just not a good idea. The only thing I can think of is to use something like super-fine sandpaper or similar to take off some of the bushings' thickness, testing often, until it swings as easily as you like, and yet minimizing the metal-to-metal contact.
steve
Visit steve's homepage!
Find all posts by steve
04-15-2003, 09:30 PM
MicJustMic
Posts: 930 - iTrader: (
I've found that just pushing the bar in and out a lot will do the same thing.
After a week or two of pulling it out three or four times a day my bars swing free.
Personally I like them to stay put, and there's another thread somewhere that I asked for some help with this.
Mic
MicJustMic
Visit MicJustMic's homepage!
Find all posts by MicJustMic
04-16-2003, 12:45 AM
frankfalbo
Posts: 1,875 - iTrader: (
You can also lube it up with some 2 in 1 oil so that although the nylon bushings might still be exerting pressure against the inner wall of the arm holder, the bar swings freely inside the bushings. In other words, bushings stay put, arm swings. That way you'd still have noise reducing tension. The other thread mentions the Schaller type arm holder. It is great for tight tension, but the tolerances are usually pretty tight, so that even if you set it to swing loosely, the arm fits perfectly in the holder so you'd get a good feel on the up and down.
frankfalbo
Find all posts by frankfalbo
04-16-2003, 01:17 AM
Posts: 19,344 - iTrader: (
Sometimes you'll get a new one that has so much [extra] grease in the holder a new bar won't stay where you put it [after the gorrila slams it into the hole because that's always the most fun on a new bar]
04-16-2003, 03:01 PM
MicJustMic
Okay, you lost me on that one Rich . . .
Mic
MicJustMic
04-16-2003, 03:05 PM
You ever try to get a new bar into a new guitar?
04-16-2003, 03:56 PM
MicJustMic
Ah yes, okay . . . NOW I get it. (I'm a little slow today)
I have a total of 10 (yes boys and girls, TEN) bars for two guitars at this point . . . so I've put them in new ones, old ones, new bars old guitars . . . so on, so on.
Yep, always a little shove is needed on those virgin bars/guitars.
Mic
MicJustMic
arm holder
bridge angle
petrucci model
pro edge
string tension
will edge zero pro fit edge 3 route?
fret setup level how-to
how to setup an edge 3 tremolo
10:56 AM
