Old 09-30-2007, 10:40 AM
texshred777  is offline
Posts: 681  -  iTrader: (2)
Reviews: 3
fender blues deluxe problem-help
I'm having a bit of a problem with my 95 fender bd. When I power up the amp, and start playing sometimes everything works fine...but sometimes I get a very loud crackly sound, almost like a speaker issue, the volume will also drop out significantly. I've noticed it's much worse when I play harder. I thought at first it was poss. a speaker issue, so I plugged an ancient boss me-30 into the effects return, to only use power amp and speaker. No problem whatsoever(it actually had a pretty decent, extremely loud sound to it). So I bought a new set of preamp tubes, thinking it might be a preamp tube problem-the tubes I believe were the originals, new ones needed anyway. I also noticed that when I adjust the presence knob, the problem will start immediately, if it's not happening yet. I'm thinking it might be a cold solder issue or a loose tube socket.
power amp, preamp tube
FS: Fender American Deluxe Stratocaster - 50th Ann. HIS ROYAL DARKNESS Classified Ads: Guitars and Gear 6 05-27-2006 07:10 PM
I've finally got the RG2820...however, one problem..advice? triaxis J-Custom, USA Custom & Prestige Ibanez Guitars 11 11-16-2003 10:06 PM
Fender Cyber Deluxe Scott 74 Gear and Equipment 4 08-14-2002 05:26 PM
having problems with my fender deluxe - Crackly mojo Gear and Equipment 1 03-12-2002 01:32 AM
Fender.. - Whats the problem?? Scoff X Other 6-string Guitars (non-Ibanez brand) 75 10-19-2001 12:52 AM
