Tech: Setup, Repairs and Mods
Floyd Rose help... - strings feel REALLY tight...
09-05-2001, 02:48 PM
Jupiter
Posts: 344 - iTrader: (
Hey guys ! I have a Dillion 7-string with *a Floyd on it, and ever since i've had it, it's felt like the strings are REALLY tight. As in it's really hard to bend a note up a full step. I've changed strings a couple times to no real effect, so it must be in the trem. It has 4 springs in the back , is that normal? Remember, it is a 7 string. Also, whenever i push the bar down for a REALLY deep divebomb, i can hear the springs creak a bit. Is that normal ? I will say one thing, though, it stays in tune like you wouldn't beleive ! WAAAAAAY better than my friends $2600 Wolfgang...and it's a $300 guitar! Hahaha! Anyway, help would be appreciated! Thanks, Ben
Jupiter
Find all posts by Jupiter
09-05-2001, 03:25 PM
jemsite
Administrator
Posts: 9,271 - iTrader: (
Floyd Rose help...
make sure the trem springs are not rubbing on the cavity anywhere. Seems like it's just stiff and this is not unexpected from an OFR variety 7-
string bridge
. The
string tension
makes for a tighter tremolo. Try lighter gauge strings for more comfort and easy bending, as the tremolo will not effect that... glen
jemsite
Find all posts by jemsite
09-05-2001, 06:29 PM
darren wilson
Posts: 4,190 - iTrader: (
Floyd Rose help...
Try taking one of the springs out so you just have three springs in the back.
darren wilson
09-05-2001, 11:08 PM
Project Guitar
Posts: 979 - iTrader: (
Floyd Rose help...
Hi Ben and welcome to the Jemsite forum!
Some people have been known to take cotton balls and put them inbetween their
trem springs
to quiet them up a bit. The amount of creaking vary's depending on the springs themsleves and also the age of them........
Project Guitar
Visit Project Guitar's homepage!
Find all posts by Project Guitar
09-06-2001, 07:19 AM
7 Dying Trees
Posts: 1,708 - iTrader: (
Floyd Rose help...
Take a spring out! You'll find everything bends a lot better. 3 springs seems to work fine!
How old is the guitsr? If it's new then it might just be that the springs ar a bit stiff...Use some cotton wool, this did seem to alleviate the problem when my bcrich was doing that (when it was new).
7 Dying Trees
Find all posts by 7 Dying Trees
09-14-2001, 02:13 PM
Jupiter
Floyd Rose help...
Hey guys, sorry i took so long to reply... * * * * * * * These all sound like good suggestions. I think taking a spring out would probably do the trick for me. But is it okay to run 3 springs on a seven string? Does anybody else here do that ? I bought the guitar in February of this year, and have used the trem quite a bit. MAN , you all wouldn't beleive how well these things stay in tune ! Buy one to at least modify, or use as a backup or something ! Anyway, back to the springs...do i just yank a spring out, or do i have to take the strings off to remove tension from the springs? I suppose i would change the formation of the springs, too. * Thanks for putting up with *my stupid guiatr tech questions , guys ! -+ben+- * *
Jupiter
09-14-2001, 03:37 PM
jay ratkowski
Posts: 2,273 - iTrader: (
Reviews: 3
Floyd Rose help...
My old UV ran 3 springs just fine... some people have problems with it though so you'll have to experiment.
As far as your high string tension (causing the stiffness)... there are tons of causes...
Here are some of the obvious ones to check
-Truss rod relief (a pefectly
straight neck
or an upward bow will cause heavy string tension... you want a slight bow for easy bending)
-Trem angle (maybe angle it forward a little - IE so the fine tuners are further away from the body rather than closer)
-Spring tension "trem play" - Dropping down to 3 springs will allow your trem to move more freely
I've amounted a ton of other theories on string tension but a lot are just for seriously anal-retentive fine tuning, and probably won't help you... stuff along the lines of
pickup height
, neck joint angle/height, string composition... etc... Try the above, possibly with the help of a local guitar tech... and you should be good to go.
Also, the cotton ball idea should work for silencing your trem, unless you want to route the cavity a little deeper...
jay ratkowski
Visit jay ratkowski's homepage!
Find all posts by jay ratkowski
09-15-2001, 08:55 AM
one less than none
Posts: 376 - iTrader: (
Floyd Rose help...
both of my seven stringers have 3 springs with no problem, if it is a new guiatr it will probably loosen up anyway but 3 springs is plenty, take one out !
one less than none
Visit one less than none's homepage!
Find all posts by one less than none
09-18-2001, 10:25 PM
YngVaiTriani
Posts: 548 - iTrader: (
Floyd Rose help...
Only use 4 or more springs if you are using heavier strings. 3 springs is all you'll need for 9's.
YngVaiTriani
Find all posts by YngVaiTriani
gauge strings
guitar tech
neck joint
pickup height
straight neck
string bridge
string tension
trem springs
truss rod
floyd roses are crap
how does the js chromeboy feel
how to replace floyd rose with ibanez zr tremolo
what kind of strings does korn use
WHAT FLOYD ROSE FITS 580 TREMOLO
04:33 AM
