Old 05-05-2002, 10:16 AM
cowcowcow  is offline
Posts: 289  -  iTrader: (0)
Floyd Rose parts......
Grr.....Where can I order a shorter Trem Blcok for my Floyd Rose Pro?
Is it the same as the edge/lo-pro edge/OFR 's trem block?
btw, which Intonation Adjustment tool should I use?
edge/lo pro edge/TRS?
Old 05-05-2002, 12:49 PM
nuno  is offline
Posts: 4,725  -  iTrader: (0)
click HERE for the short trem-block, click on 'Miscellaneous Bridges Parts' on the left, and then click the item #BP0270-001.
click HERE for the intonation tool.
let me know.
Old 05-05-2002, 01:25 PM
grr........a stupid question.......
HOW CAN I ORDER THE PARTS ON ALLPARTS WEBSITE?.......
Old 05-05-2002, 02:19 PM
yurich  is offline
Posts: 655  -  iTrader: (0)
http://www.allparts.com/allparts/apl...order?openform
Old 05-06-2002, 02:16 AM
toshiro  is offline
Posts: 1,812  -  iTrader: (11)
The Allparts block will not fit a Floyd Rose Pro.
I bought one for mine, and the mounting screw holes on it did not line up at all. I've since sold the bridge to a friend, who is having this same, too long of a block, problem. We called Fender, no go on a shorter block..
This week we should be pulling it back out, and he's gonna take the block to a machine shop and have it shortened. Seems the easiest fix for this.
Doesn't make any sence to me though, why have the long block standard on a low profile trem? Sometimes I just don't understand parts manufacturers..
Old 05-06-2002, 04:05 AM
nuno  is offline
sorry cowcowcow...
thanx for the advice Toshiro.
i think anyway that the low profile version of a Floyd type bridge has only to do with the shape of its tail, not with the thickness of the guitar on which its installed.
i mean, you should get a shorter block when you install a Floyd on a guitar that's thinner than the standard Fender or Jackson, for ex: an RG270 or a 540PII.
Old 05-06-2002, 05:05 AM
toshiro  is offline
That's just it though, my friend's guitar is a Jackson V.
The long block was 'supposed' to be for non-routed installations, where it needed to go all the way through from the top of the guitar to the bottom. You'd think a low profile system, which 9 times out of 10 goes into a top routed guitar, would come stock with the short block..
Oh well, it just makes me kinda mad, no one should have to go through all this with a brand-new, high end, bridge.
Old 05-06-2002, 05:36 AM
nuno  is offline
...that's for sure!
you're right Toshiro, i'd forgot about the routed/non-routed thing...
floyd rose, floyd rose pro, intonation tool, pro edge, trem block
