Tech: Setup, Repairs and Mods
Floyd Rose tremolo and nut widths? help
03-31-2008, 08:42 AM
vejiita
Posts: 56 - iTrader: (
I am buying a replacement for my
floyd rose
in my guitar. I measure the nut width of my guitar to be
1.44 inch.. so should i buy a floyd rose with a nut width of
1) 1 5/8"
2) 1 11/16"
3) 1 9/16"
which one is going to fit in my guitar?
vejiita
Find all posts by vejiita
03-31-2008, 12:18 PM
losgatosrg350dx
Posts: 848 - iTrader: (
Re: Floyd Rose tremolo and nut widths? help
math major anyone?
losgatosrg350dx
Find all posts by losgatosrg350dx
03-31-2008, 12:25 PM
albee1952
Posts: 784 - iTrader: (
None of them will fit. I suggest you measure again as 1.44" is less than and inch and a half which makes me think you did not measure right as I have never seen a 6 string neck that narrow. If you are buying an American measured nut, measure the neck with a ruler so you don't need to convert. BTW, 1 5/8"=42mm and 1 11/16"=43mm. These are the 2 most common nut sizes.
albee1952
Find all posts by albee1952
04-07-2008, 10:41 AM
Zepp3lin
Posts: 200 - iTrader: (
Reviews: 12
The most common is 43mm or R2 on the nut side.
Zepp3lin
Find all posts by Zepp3lin
04-07-2008, 09:54 PM
albee1952
Well, R2 is actually a 42mm or inch and 5/8ths. 43mm is equal to original Floyd Rose R3 or R4 (same overall width but different string spacing for bound and unbound fretboards).
albee1952
04-08-2008, 11:32 AM
Zepp3lin
Reviews: 12
ok my mistake its 43mm R3, because originally its a floyd so string spacing should not be a problem if you choose the correct 1. its not like his changing a
ibanez trem
to a floyd.
Zepp3lin
04-08-2008, 04:11 PM
rdm
Posts: 82 - iTrader: (
If you swap the bridge, do you have to change the nut if you go from an Ibanez bridge to an OFR bridge?
rdm
Find all posts by rdm
04-08-2008, 04:16 PM
Drew
Posts: 4,538 - iTrader: (
rdm
I just did this the other weekend to a PWH. No, you don't. I kind of wanted to, since it was a chrome bridge on a guitar with a black nut, but the alignment was a little funky so I left the original on. It's worked like a charm so far.
Drew
Visit Drew's homepage!
Find all posts by Drew
floyd rose
ibanez trem
how to replace floyd rose with ibanez zr tremolo
floyd rose change scale length?
WHAT FLOYD ROSE FITS 580 TREMOLO
floyd rose on pac112?
02:08 AM
