Old 02-25-2003, 07:47 PM
Karmann  is offline
Posts: 69  -  iTrader: (0)
Floyd w/o locking nut
Is it possible to have a guitar, let's say a strat, for example, fitted with a FR tremolo( not floating, like the Peavey Wolfgang) with d-tuna and instead of the locking nut, have locking tuners and a LSR nut or something similar?
Old 02-25-2003, 08:47 PM
sniperfrommars1  is offline
Posts: 3,302  -  iTrader: (0)
Yes it is. Ive seen a few people that do this, one of my buddys has a wolfgang he doesnt use the locking pads with. I hate it. lol. No reason to lose the locking nut in my opinion. I remember the days without the nut and therefore hate the ideal of going back to no locks
Old 02-25-2003, 08:54 PM
BeastofLove  is offline
Posts: 795  -  iTrader: (0)
Sniper- help me out here...
What's the difference between a locking nut, and let's say, Sperzel locking tuners? I would think easier string changes and solving tuning problems would be easier without having those 3 extra pads there. It should be just as good, esp. if you had one of those roller nuts...
-Ben
Old 02-25-2003, 10:58 PM
JESTER700  is offline
Posts: 2,234  -  iTrader: (0)
If you're REALLY wild on the whammy, you can't beat a locking nut. If you're not, you can go with Sperzels (and yeah - with rollers it's better yet). But if you're going THERE, why even use a floyd? Get a Wilkinson or something.
Old 02-26-2003, 12:10 AM
Akhenaten  is offline
Posts: 728  -  iTrader: (1)
While it's alot less of an issue with locking tuners, there's still the instance of the string moving back and forth in the nut slots. And they don't always return in tune. With a locking nut, you cut the movement there, and thus the strings don't have opportunity to catch in the nut in a different spot.
Old 02-26-2003, 11:37 AM
Drew  is offline
Posts: 4,538  -  iTrader: (4)
There's also the fact that if you really abuse a FR trem, it's possible for the strings to fall out of the nut entirely when you dive down... Try it on a guitar with a locking nut. see how they just hang there?
I really wouldn't recommend this.
-Drew
Old 02-26-2003, 08:31 PM
the major weak point at the headstock is the nut, string tree and the wraps. EVH used to wind his wraps upside down and only one or two twist per string. A little lube in the nut (*no pun intended*), and he would also straighten the string very carefully when winding to pitch. This will help you stay in tune a lot better with a vintage style setup. SPerzels dont compare to the floyd because they have the three major weak points still there. Ive seen guitars that stay in tune Moderately well without the locking nut, but usually not. So in my opinion, its fixed bridge or floyd. Why settle for less than perfection?
Old 02-26-2003, 10:13 PM
Well, my Parker doesn't have string trees, and with locking tuners (Sperzels), I don't have to do any wraps around a post. So there's only 1 weak point according to you- the nut. I've dive bombed until the strings are limp and pulled up until I popped my G-string and have yet to have a problem with tuning stability.
As for strings popping out of the nut during a dive-bomb, with a roller nut, it's impossible for the strings to come out (I also had a Strat Ultra) since they go over one roller and UNDER the second roller.
Now, I'm not about to go converting my Ibz' with Sperzels and roller nuts, but I'm also not ready to give a hefty advantage to the whole Floyd-style locking system over locking tuners + roller nut.
-Ben
Old 02-26-2003, 10:56 PM
Ill hand it to parker they stay in tune well. My friend said the same thing about his parker, and I knocked it out of tune in 30 seconds. The strings still slip at the tuner a small bit even on the parker, Nice setup though. I wouldnt mind having one in a nice purple color
Old 02-27-2003, 12:18 AM
The nut is everything...if the slots are nicely done, you will very likely have no real problems with your Sperzels. If the slots are too wide, the strings rattle. If too narrow, they hang up in it. Seems you've already made up your mind "Beast...". Go with the old rule, "If it works for you, then use it." Just remember that sometimes you get lucky with guitars. One may be great, and an identical one may suck. A good setup works wonders... You could have a locking nut behind a roller nut with a locking bridge and locking tuners, and if you didn't stretch your strings, you're wasting time.
Old 02-27-2003, 01:17 AM
bryangraye  is offline
Posts: 128  -  iTrader: (0)
I seem to have mastered the art of rapidly altering tuning through playing. .... sort of the same story with PCs - if it can be crashed, I'll find out how.
Old 02-27-2003, 11:40 AM
huh?
Old 02-27-2003, 07:45 PM
Same here, if its gonna break down I push the limit till it does.
Old 02-27-2003, 09:08 PM
Yep- that's why I haven't modified my locking Ibanez's. Not going to screw with something that works!
Of course!! String stretcher for quite a while now As I'm sure everyone here is.
-Ben
fixed bridge, locking bridge, locking nut, locking tuners, peavey wolfgang, sperzel locking, sperzel locking tuners, string tree, string trees
