Old 03-21-2005, 05:15 PM
megadeth  is offline
Posts: 1,221  -  iTrader: (10)
Question
Fred-yjm-paf Pro ?
i have a H-S-H style body. i have decided on 2 humbuckers i.e PAF PRO and FRED (trying to get satriani sound). I wanted to know if i can put YJM pickup for a single coil for a totally different sound ? it is feasible? what kind of changes will be needed in the setup?
Old 03-21-2005, 06:22 PM
Uthark  is offline
Posts: 150  -  iTrader: (0)
Re: Fred-yjm-paf Pro ?
Maybe you should consider the PAF Joe instead of the PAF Pro.
Old 03-21-2005, 09:25 PM
megadeth  is offline
any specific reason ?
also i need to know about the single coil pickup i have chosen
Old 03-22-2005, 01:24 AM
Shep  is offline
Posts: 542  -  iTrader: (1)
satch never has really used H-S-H config
YJM is ok but a HS-2 is better for those two pick up's.
Old 03-22-2005, 01:25 AM
Shep  is offline
PAF joe is like a PAF PRO with abit more of a les paul sound
Old 03-22-2005, 02:37 PM
megadeth  is offline
can u tell more about HS-2 ?
Old 03-22-2005, 06:15 PM
RGShredder  is offline
Posts: 26  -  iTrader: (0)
The HS-2 is a good choice for the setup your looking for. I'm not too familiar with the YJM but it sounds like it's more of a stand alone pup. I think it (YJM) will sound fine alone, but can't really say what you'll hear if you couple it to the neck or bridge. Best to compare the output of the YJM to that of the HS-2 to really get a feel for what to expect.
I've heard Blue velvet is also a good single (sorry to throw another option in your pup scheme).
Since Satch's set up is H-H, I'd say get a super switch and wire it with a pull push tap this way you can have the typical H-S-H w/ the 5 way toggle , as well as having the capabilities of bridging the two humbucks when tapped. I could go into detail, but I'm tired....
good luck
--RG
Old 03-22-2005, 09:17 PM
megadeth  is offline
i have a JEM style body
but i have no guitar with PAfs and Fred...hence i chose these pickups.. but i needed a single coil too....
Old 03-23-2005, 12:35 AM
Shep  is offline
the hs-2 is alot like a jem middle but made to suit the Fred, PAF Pro,Joe....... so on. it's a great p/up and a good replacement.
coil pickup, jem style body, les paul, paf joe, paf pro
almost there with the fred pick up instal just alittle more Jslegacy Pickups & wiring 3 06-12-2003 01:41 AM
Gentlemen A new FRED for a Friend now i need help! Jslegacy Pickups & wiring 3 06-01-2003 01:55 PM
Replacing an Ibanez pup with a dimarzio FRED warjockey Pickups & wiring 0 05-23-2003 04:22 PM
Recommendation for S1520 owners: DiMarzio FRED and PAF Pro gitarrero Pickups & wiring 12 04-21-2003 05:01 AM
Help! New pickups in JS100 Sound bad? - PAF pro and Fred sou Voodoosoup JS (Satriani Model) Ibanez Guitars 6 03-27-2001 08:27 PM
