Tech: Setup, Repairs and Mods
Fret Buzz problem, lower 3 strings only.
03-31-2006, 12:25 PM
SidewinderINC
Posts: 44 - iTrader: (
Hi all,
ive started to notice quite badly a
fret buzz
problem ive got on my RG3120, and i'm not sure how to fix it.
its only on the low E, A and D strings, and only on the bottom 5 frets of each string.
ive tried raising the bridge to no avail as that just made the action further up the neck unbearable by the time it was high enough to remove the buzz down to 4th fret!
is there anything more i can personally do? or would i be best to just take it into a fixers?
Cheers
Matt
SidewinderINC
Find all posts by SidewinderINC
03-31-2006, 12:49 PM
southpaw_lefty
Posts: 1,140 - iTrader: (
Re: Fret Buzz problem, lower 3 strings only.
You could try to loosen the
truss rod
some and add some bow to the neck. Check the tech section.
southpaw_lefty
Find all posts by southpaw_lefty
04-01-2006, 08:02 AM
SidewinderINC
awesome, thanks a lot for that. will give that a go tonight
SidewinderINC
04-02-2006, 02:18 PM
SidewinderINC
i cant get access to the
truss rod nut
without taking all of the strings off... or at least the middle two. is it best to do this with the strings on or off?
SidewinderINC
04-02-2006, 03:14 PM
Jaden
Posts: 2,464 - iTrader: (
sure you can....
I used a deep reach socket with and extension bar a ratchet handle to adjust mine.
you need to adjust the neck while its under its load from the strings anyway so removing strings would be a no-go.
when you make your adjustment give it twenty minutes of playing to let the neck relax into its new position before making another change.
Jaden
Visit Jaden's homepage!
Find all posts by Jaden
04-02-2006, 03:44 PM
SidewinderINC
you're right, i just need to get a new very narrow walled socket! its only cause the walls are too thick on my current 7mm socket that it wont fit past the strings haha. doubt it'll even fit inside the gap around the rod!
tomorrow ive gotta hunt for a narrow walled one then
SidewinderINC
04-02-2006, 04:12 PM
Jaden
Exactly, I have a set that I use for work.
a normal socket is too wide. good luck with the hunt.
Jaden
fret buzz
truss rod
truss rod nut
how to change strings on js 1200
how to lower action on peavey wolfgang
how to get rid of string buzz
what kind of strings does korn use
how to fret level
RG fret buzz issue
pedalinbob
03:19 AM
Sorting out fret buzz, without lowering action?
Swirly
11:36 AM
Known history of Guitar.. (lots of people have it wrong) - a
vwall
Archived Topics and Common Questions - GO HERE FIRST
01:44 PM
Fret Dressing How To - Not for the weak of stomach
Kyle Odom
05:06 PM
vwall
02:20 AM
07:27 AM
