Old 08-20-2006, 01:32 PM
Glados  is offline
Posts: 53  -  iTrader: (1)
Fret buzz :( Rich help me please
Hi!!!
Rich help me please.. i have just leveled my frets, dressed them and polished them.
But after i restring it i got a great action and no buzz from 0.5 mm to 2.0 mm
i know i like a action for about 1.5 to 2.0 mm. But the problem is that from 1.5 - 2.0 mm i have no buzz what so ever exept on my first fret the low E and the A string and the rest i perfect as it can be..
I haveing big trouble to resolve that problem since i have no buzz at 0.5 mm and up on everey fret execpt the first at LOW E and A string. the rest of the strings like D G B E are perfect.
Can you help me to resolve this???
By the way i did the fretwork yesterday.. so it is up to date.
Sorry for my bad english.
All the best
Glados
Old 08-20-2006, 01:57 PM
Drew  is offline
Posts: 4,538  -  iTrader: (4)
Re: Fret buzz :( Rich help me please
1.5mm is absurdly low action for one. .5mm? I don't think I could physically play a guitar with action that low.
So, is it the first fret that buzzes when you play an open string, but whenyou fret it doesn't? Or when you fret the first fret you get buzz but nowhere else?
If it's the former, you need to shim your nut slightly higher. If it's the later, my gut feeling is you need SLIGHTLY more neck relief.
If you're trying to set your guitar up with .5mm action, however, I suspect that's probably the root of the problem.
Old 08-20-2006, 02:16 PM
markg5150  is offline
Posts: 2,361  -  iTrader: (2)
+1
I take you don't bend strings much with an action that low
Old 08-20-2006, 02:38 PM
Glados  is offline
hehe you guys
yeah i like to play solo and bend with .5 mm action then i got a great and long sustain )
hehe seriosly i use 1.5 up to 2.0 mm.
i have buzz only when i pluck the E and A at first fret open string sound great i have just removed a shim from the nut because it was way to high.. that result gave me less buzz on those string but i cant undretstand why only those and no other string or fret buzz..
the neck is right setup because anything else plays smooth execpt 2 strings at first fret. my OFR is also perfect..
That is the tricky shxxt..
Glados
Old 08-20-2006, 03:04 PM
Drew  is offline
Then it's probably a second fret that's SLIGHTLY high at the low E side.
Old 08-20-2006, 09:47 PM
sniperfrommars1  is offline
Posts: 3,302  -  iTrader: (0)
The english is a bit strange but I think you only have open string buzz. If you read over rich's tutorials some is somewhat normal for an optimal setup. IMO lower than 2mm is too low for sweeping, heavy bending etc. but to each their own.
Old 08-20-2006, 11:10 PM
Rich  is offline
If it's unwanted open string buzz either raise the bass side of the nut or add a little neck relief.
Old 08-21-2006, 08:04 PM
Glados  is offline
Smile
i dont have problem with open string buzz.... no where at the board.
the buzz comes only when i hit the Low E and the A string on the first fret thats it..
nothing more nothing less
yeah i have a little relief but no my action is 2.5 mm it is a little bit to high for me and my fingers.. i play light
hakuna ma tata
Old 08-21-2006, 08:08 PM
Rich  is offline
Without seeing it I'd suspect a little scarf-joint-itis. [first fret backbow]
Old 08-21-2006, 08:14 PM
Glados  is offline
how can it be? i've just leveled the neck with the stone and then with 1200 paper as polish
why not the other stings at the first fret??
Old 08-21-2006, 08:21 PM
Rich  is offline
The other strings don't occilate as big so don't need as much clearance.
I suggest you check this thread
http://www.jemsite.com/forums/showthread.php?t=51034
Old 08-21-2006, 08:32 PM
Glados  is offline
i read everything there... i sat the neck straight as possible ididnt use any support to the neck and did not use great force either i used almost a day to do it carefully and still not perfect.. my pickup are right and trem...
i give up soon
is the first fret at the top E A to low??
Old 08-21-2006, 08:38 PM
Rich  is offline
All you did was take equal amounts off of all the frets, that doesn't level anything, and if the neck is showing tendency to backbow it has to be cut stressed, and the only way to cut any neck level is with an 18" milled bar with Stickit paper.
fret buzz, neck relief
Fret buzz at 2nd fret aj_foes Tech: Setup, Repairs and Mods 2 04-19-2006 05:06 AM
How to elimate fret buzz completely in a guitar? zerolight Tech: Setup, Repairs and Mods 16 10-27-2003 01:06 PM
Fret Buzz from frets 11-14...? Drew Tech: Setup, Repairs and Mods 8 02-18-2003 12:02 PM
Fixing Fret Buzz - on only a single note! mechanyx Tech: Setup, Repairs and Mods 7 04-03-2002 04:15 PM
Fret Dressing How To - Not for the weak of stomach Kyle Odom Tech: Setup, Repairs and Mods 6 08-23-2001 05:06 PM
