Tech: Setup, Repairs and Mods
Fret wear and dull knife blades - possible solution?
11-28-2002, 12:38 PM
JMR
Posts: 3 - iTrader: (
I just ask you experts an opinion about fret wear and problems with
floating bridges
. As far as I know wearing of frets and knife blades generates all sorts of problems. How if frets and knife blades could be coated with very hard material - diamond. I know person able of coating metal surfaces with thin layers of diamond. Method is relatively cheap and could be used to enhance top of the line guitars. Coating is extremely hard and lasts forever. Only problem is that coated surfaces can not be bended - possible problem for installing coated frets. How much for example stainless stell
jumbo frets
need to be bended when installed? Or is it bend at all?
JMR
Find all posts by JMR
11-28-2002, 12:46 PM
Paul Secondino
Posts: 401 - iTrader: (
I dont think diamond coatings are practical for guitars,especially frets.Frtes need ot be hard but at the same time machineable and super smooth.I have never felt a diamond coated anything that was smooth enough to be used as fret material.
Stainless steel frets
are the hardest frets available at the moment..You can go to Warmoth's wwebsite to check it out
Paul Secondino
Visit Paul Secondino's homepage!
Find all posts by Paul Secondino
11-28-2002, 12:51 PM
JMR
Actually diamond coated surfaces are extremely smooth. We have proved in our research work that two coated diamond surfaces are nearly frictioneless. You cannot get any smoother surface than that.
JMR
11-28-2002, 05:00 PM
toshiro
Posts: 1,812 - iTrader: (
How doe this work anyway? Diamond coat? Any facets would make it worthless, as they would cut the string..
Frets need to be bent, either by hand, or using a fret-press, to the radius of the fretboard.. That as we know, varies by guitar.. hehe
toshiro
Visit toshiro's homepage!
Find all posts by toshiro
11-28-2002, 05:11 PM
littlegreenman
Posts: 2,626 - iTrader: (
from someone who has worked in the machining industry, and dealt with alot of tooling that has diamond coating, I know it is fabulous, I also know it would not help with the knife edges, the diamond coating may not wear quickly, but the dulling of the edge is a product of the metal moving more than wearing. The diamond coating would not last on an edge for long. Also, the posts wear as fast or faster than the knife edge.
As for frets, coating the fret would be pointless as a nickel fret is still soft, and will still ding as easily, THEN, should you ding a fret, your
local luthier
would curse you, plus the diamond coating really isn't effective on a soft metal, diamond coating is used on tool steels primarily
littlegreenman
Visit littlegreenman's homepage!
Find all posts by littlegreenman
11-28-2002, 05:15 PM
darren wilson
Posts: 4,190 - iTrader: (
toshiro
Facets? You know those are cut into the gem stones, right? I don't think he's talking about diamon-encrusted frets.
JMR: Can you explain a bit more about the diamond-coating process? The only way i can see it working for frets is if the frets are pre-cut and pre-bent to a specific radius, which would be impractical as an aftermarket replacement product for all guitars, but may work in a situation where you're making them to order.
Even still, if you've got a super-hard surface like that, how do you level the frets to get the playing surface even? You need to have
some
ability to work on the fret crowns.
darren wilson
11-29-2002, 01:14 AM
JMR
Coating is made by patented technique from graphite. Coated surface can be adjusted to have either very much friction or super smooth nerly frictionless. Thickness of the coating can be adjusted also and it can be less than 1 micrometer thick. I suppose the best case would be coated stainless
steel frets
. I also think that fret should be pre-cut and pre-bend. The problem arises if frets should be leveled after instalation. Coated surface is impossible to sand down so it might ruin the idea.
JMR
11-29-2002, 01:29 AM
darren wilson
Stainless frets
are already much harder than most guitar strings, so i doubt there'd be much benefit to adding an even harder coating on them.
Really interesting idea, though.
darren wilson
11-29-2002, 07:17 PM
BZ Beetle
Posts: 328 - iTrader: (
uhhh.........wouldnt hard frets wear strings through fast? I thought that was why stainless frets arent that popular
BZ Beetle
Find all posts by BZ Beetle
11-29-2002, 08:23 PM
Reaper
Posts: 599 - iTrader: (
I don't think they do. The main reason, I think, is because stainless steel is harder to bend, and therefore, harder to fret a guitar with.
Reaper
Find all posts by Reaper
11-30-2002, 12:19 AM
BZ Beetle
we went over the topic in detail on the fender forum a LONG ways back. we collectively came to the conclusion that the reason why they dont put stainless frets on all guitars is because they would eat the strings, where as softer frets would wear faster. *shrugs* im sure theres a plethora of reasons
BZ Beetle
floating bridges
jumbo frets
local luthier
stainless frets
stainless steel frets
steel frets
how to fix fret board separation
warmoth 24 fret?
neck what your low action jackson "24th fret"
how to fret level
27 fret guitars?
03:07 PM
