Old 06-11-2003, 06:23 PM
KurtCobain  is offline
Posts: 77  -  iTrader: (1)
glue on JEM. HELP ME
Hi,
first off all, sorry for my bad english an thanx for any suggestion, so here's my problem.
I bouhgt an Ibanez JEM 7 VWH on ebay last week. Im very happy with it except one thing, the seller told me (an i saw it one the, very thiny) pic there is an sticker (hemp leaf) behind the floyd rose. I said its okay, Ill whatch it and if it looks good i'll keep it. So today i got the guitar an...surprise....wasnt a sticker...it was a plastic hemp leaf glued on the guitar....i got it off but theres still much glue on the lac. Does anyone know how to fix my little problem? Nice guitar....but only without glue.
Thx,
Kurt
Old 06-11-2003, 06:36 PM
vaijem777  is offline
Posts: 2,980  -  iTrader: (17)
First, try to find out what kind of glue it is. If it's super glue, there are solvents that will remove it. Chances are, if it IS super glue, it's probably melted the finish a bit so it'll leave a scar. There will probably be some sort of finish blemish no matter what kind of glue it was (unless it's Elmer's glue!) I'd try a warm, damp cloth first and see if it's a water-soluble adhesive.
Old 06-11-2003, 06:47 PM
I knew I'll probably some finish blemish but better than the glue(which is also brown by the leaf). I asked the seller but he doesnt know what kind of glue it was....the problem is i dont know how the lac will reakt on solvents.
But thank you so far.
Old 06-11-2003, 06:49 PM
jemsite  is offline
Administrator
Posts: 9,271  -  iTrader: (5)
Images: 11
that clearcoat is impervious to most solvents... not that you want to try.
i'd use a hot rag or gentle steam on it to see if the glue softens, then rubbing alcohol and elbow grease if needed. i'd then try lighter fluid and as a last resort "goo gone" citric acid type (not paint thinner type) glue remover... glen
Old 06-11-2003, 06:58 PM
If the glue is brown, it MIGHT be a type of hide glue or wood glue...if that's the case, a warm, damp cloth might remove it
Old 06-11-2003, 07:54 PM
jerrye  is offline
Posts: 514  -  iTrader: (0)
dude, glue or not if this is Kurt Cobain, i must have missed the last 10 years or so???
Old 06-12-2003, 09:03 AM
kent k  is offline
Posts: 179  -  iTrader: (12)
Use mineral spirits on a rag and rub until it comes off. Wear gloves and don't breathe it. Mineral spirits is excellent for this kind of thing, and will dissolve most adhesives except superglue or epoxy which you'll probably need acetone for. The poly-ester finish on the Jem shouldn't be harmed by either of those solvents, but just in case, take the back trem cover off and wipe some of each solvent on the paint inside the cavity to see if it will react. If it doesn't do anything weird, then you are safe to try it on the front of the guitar. Good luck.
Old 06-12-2003, 05:23 PM
hi,
thx again. But what the f**k is "mineral spirits"? Can you describe it 'cause i dont have the german translation. Thx again.
Kurt
Old 06-12-2003, 05:41 PM
kent k  is offline
It is most commonly used as a paint thinner. I think it has benzene as the primary solvent in it. You must have it over there, but I don't know what it would be called. Here is a link to a place that sells it here:
&lt;a href = http://woodworker.com/cgi-bin/FULLPRES.exe?PARTNUM=849-328&ov=2988&KEY=MINERAL+SPIRITS>http://woodworker.com/cgi-bin/FULLPRES.exe?PARTNUM=849-328&ov=2988&KEY=MINERAL+SPIRITS&lt;/a>
I don't think they'll ship it overseas, but I'm sure you can find it in a hardware or paint shop locally.
Old 06-12-2003, 05:43 PM
kent k  is offline
Not sure why the straight html didn't work, I'll try this;
http://woodworker.com/cgi-bin/FULLPR...INERAL+SPIRITS
Old 06-14-2003, 10:06 AM
do you mean a spacial kind of benzin?
Old 06-15-2003, 11:38 AM
Hi,
I just brwosed the web searching for help and everybody sais "use acetone for superglue" (i think it is superglue) but wont it damage the lac?
I just took some photos too, can see them here:
http://home.t-online.de/home/kristkurtdave/
(only the .jpg's *g*)
[EDIT]
The Glue is gone, I used Acetone. Took me about 4 hours and my fingers hurt like hell buts no more glue. Thx for your help, thread can be closed.
[/EDIT]
floyd rose, ibanez jem, kurt cobain
