Old 05-15-2007, 01:58 PM
seongkeat  is offline
Posts: 116  -  iTrader: (0)
Guitar buzz problem...
HI all Pros here.. i want to ask for help because my rg2620 has some buzzing problem...
When i try to bend the high E string at the 15th fret... it seems like the sound will cut off by the buzz... means that it will sound like (tiiuuuu~~ STOP ) even if it is not bend up... it will have some slightly buzz... and the B string also have the buzzing problem on the 15th fret...
It is the neck problem or the bridge problem ?
i have send this guitar to tech for few times already... but than the problems still cannot be fixed... when install a set of new string... it will not buzz that serious... but it will have a slightly little small buzz which u need to listen properly...
since i have sent so many times to the tech but h still couldn't fix it... i would like to try myself... so any PROS here please give a hand... thanks !!!
Old 05-15-2007, 02:05 PM
djpharoah  is offline
Posts: 369  -  iTrader: (6)
Reviews: 5
Re: Guitar buzz problem...
It sounds like a dead spot on your fretboard. What you want to try is raising the action up a bit on the guitar, raising your strings might eliminate the dead spot.
Old 05-15-2007, 02:11 PM
mi2tom  is offline
Posts: 7,522  -  iTrader: (4)
I bet art tune's din can fix it
Old 05-15-2007, 03:59 PM
i have sent there for 2 times ler... but after service... it still have a little buzz.. thats why i have no idea with it... so try to get some help here see whether can fix it or not ... hehe
Old 05-15-2007, 05:25 PM
TheBoss84  is offline
Posts: 60  -  iTrader: (0)
Whats your guitar? I have the same problem on my squier too. If i play the B string when i reach 15 and below(21) it buzzes and produces a muted sound.
Old 05-16-2007, 12:47 AM
I m using the prestige RG 2620... my problem mayb slightly different than urs... the buzz only happened on the 15th fret of high E string n B string... if u play at 14th or 16th there are no problem at all... so i think this is weird...
Old 05-17-2007, 05:10 AM
anyone here ???
Old 05-17-2007, 08:37 AM
jb4674  is offline
Posts: 4,010  -  iTrader: (0)
Reviews: 6
Try getting the frets leveled. Since there's a dead spot, leveling the frets should even the action everywhere. Did the tech adjust the truss? I think that should've been the first thing he should've checked. Maybe Rich can have a better perspective on the situation if he's around....
Jimmy
Old 05-17-2007, 08:38 AM
neptoess  is offline
Posts: 303  -  iTrader: (0)
sounds like the same problem that happened with my NJ Classic Bich(neckthru, 24 fret ebony board, quilted maple top, $350 new from MF). The 14th fret on all the strings would buzz even with the action half an inch off the board or higher. I looked and measured and noticed this fret was oddly lower than the other ones. So I blamed it on the factory, called MF for a replacement, they were all out and couldnt replace it with a diff color, so i got my money, went to GC, and bought an ibanez. If you have any experience with fretting, changing that fret would probably fix the problem. If you let it go chances are good it will eventually become so low that if u fret at the 15th itll sound out like you're fretting at the 16th. You could also file ALL the other frets down but that's a PITA
Edit: LEVELING, that's what it's called. Yea get your frets leveled and if they're all level besides that one change it out I guess, I'm not really experienced with any of this I'm just going off what other forums told me to do with the Rich
Guitar amp problem - Help! - Budda SD30 RiverKing Gear and Equipment 10 05-02-2007 03:13 PM
Neck shim/action alchemy to get buzz free guitar Vinco Tech: Setup, Repairs and Mods 2 05-09-2006 03:25 PM
please post your funniest sounding guitar problem latinjem7vwh Tech: Setup, Repairs and Mods 10 02-25-2003 02:03 PM
The Musikk Praksis interview - Followup to the Acoustic JEM SalemB Archived Topics and Common Questions - GO HERE FIRST 12 07-09-2002 04:09 PM
Known history of Guitar.. (lots of people have it wrong) - a vwall Archived Topics and Common Questions - GO HERE FIRST 20 12-30-2001 01:44 PM
