Old 02-19-2007, 05:08 PM
Al M  is offline
Posts: 551  -  iTrader: (0)
Guitar wiring problems
Does anyone know the likely problem that is causing my guitar's volume pot to be more like an on off switch. There is variation in the volume, but it all happens within a degree or two or a turn. The guitar is recently built and I've tried changing the volume pot, so I'm assuming that its a wiring problem.
Cheers
Al
Old 02-19-2007, 05:13 PM
crevis  is offline
Posts: 2,599  -  iTrader: (1)
Re: Guitar wiring problems
Are the pickups passive or active and what pots are you using?
Old 02-19-2007, 05:16 PM
Al M  is offline
Hi, the pups are passive, i'll have to open it up and check on the pots. The guitar is hum single hum with a 5 way blade switch going bridge, bridge and middle, middle, middle and neck, neck. then there's 3 micro switched, the first coil taps the neck, the second inverts the phase of the single coil and the third taps the bridge. one tone, and one volume.
Old 02-19-2007, 05:17 PM
djohns74  is offline
Posts: 580  -  iTrader: (0)
I wonder if something like this could be caused by one of the pots being wired incorrectly? I'd probably pull the tone control out of the loop, which should be removing a single wire, and see if that changes anything.
Old 02-19-2007, 05:30 PM
crevis  is offline
I remember I had a problem similar and it was jack. I can't quite remember exactly what was wrong but I know it was the jack because it worked after I installed a new one.
Old 02-19-2007, 05:36 PM
Al M  is offline
By that do you mean the socket? I might also point out that theres a slight crackle when volume changes occur that can be heard if the amp volume is turned up.
Old 02-19-2007, 05:52 PM
crevis  is offline
Yeah the socket.
Old 02-19-2007, 07:24 PM
ryanb  is offline
Posts: 1,457  -  iTrader: (0)
Replace your linear-taper volume pot with an audio-taper pot and it will be fine.
Old 02-19-2007, 07:35 PM
crevis  is offline
I don't think that would be it unless it's neither a log or linear pot.
Old 02-19-2007, 07:41 PM
ryanb  is offline
An audio-taper pot is a "log" pot.
Old 02-19-2007, 07:43 PM
crevis  is offline
yeah and?...
coil tap
help me....laquer problems projectjem Tech: Setup, Repairs and Mods 47 03-12-2009 01:49 AM
finished wiring but have problems, please help! jpwannabe Pickups & wiring 2 07-13-2004 08:37 AM
Guitar Wiring 101 What do I need to know? sniperfrommars1 Pickups & wiring 6 05-29-2004 01:44 PM
Known history of Guitar.. (lots of people have it wrong) - a vwall Archived Topics and Common Questions - GO HERE FIRST 20 12-30-2001 01:44 PM
tuning problems are over - new guitar chip james JEM and Universe Guitars 2 02-01-2001 10:48 PM
