Old 04-12-2008, 02:29 PM
Hamer098  is offline
Posts: 182  -  iTrader: (0)
Hardtail Problem
Hey i changed the strings on my friends hardtail Ibanez and the bridge just kinda popped out from its cavity. I took some pictures of that:
How do i fix that? Should i adjust the neck angle or what?
Old 04-12-2008, 02:38 PM
ColinMmmmm  is offline
Posts: 1,068  -  iTrader: (1)
Re: Hardtail Problem
Thats not a hardtail. Thats a trem if I've ever seen one.
Old 04-12-2008, 02:55 PM
Hamer098  is offline
Than thats a hardtail tremelo How do i fix it?
Old 04-12-2008, 03:19 PM
CosmicDebris  is online
Posts: 3,216  -  iTrader: (4)
It almost looks like the studs have pulled up out of the body. If that is the case then take it to a pro to fix if it can be fixed. If not just screw the studs down. Make sure the knife edges are properly seated etc.
Old 04-12-2008, 03:33 PM
Hamer098  is offline
Right now it has only 2 springs on the back, might that be the problem?
Old 04-12-2008, 03:35 PM
toneboy  is offline
Posts: 1,665  -  iTrader: (2)
Do you know if you went up a gauge or two from the original strings? That would explain why the bridge is pulling up.
The studs look fine to me.
How many springs are in the back? If he's not using trem, you can either put 5 springs in and rebalance the bridge or just block off the bridge's sustain block in the front and rear.
Old 04-12-2008, 04:15 PM
Hamer098  is offline
Well i didnt change the gauge of the strings they are still regular slinkys, and as i said before there are two springs on the back. I also took a picture of the back
Old 04-12-2008, 04:18 PM
elcid  is offline
Posts: 8,718  -  iTrader: (12)
It can be a hardtail or a trem, not both. Clearly it's a trem and the string that were put on were too heavy. Easiest fix is to replace the strings with the original gauge, otherwise add a spring or try tightening the claw.
Old 04-12-2008, 04:27 PM
Did you lose a spring?
Old 04-12-2008, 04:32 PM
Hamer098  is offline
No i still have it im going to try to put it in and see what happens :P
Old 04-12-2008, 04:39 PM
Well if you took one out and still used the same gauge strings then there is yor problem.
Old 04-12-2008, 04:49 PM
Hamer098  is offline
Yup, that was the problem, thanks for help everyone (except elcid of course :P)
Old 04-12-2008, 05:58 PM
jb4674  is offline
Posts: 4,010  -  iTrader: (0)
Reviews: 6
Put the springs in a straight configuration as opposed to an arrow config. Also, for future reference, there isn't a hardtail tremolo. You either have a hardtail (a guitar with a fixed bridge that doesn't move) or you have one with a tremolo. Whether it's a fulcrum style or a floyd, it's still a tremolo.
Jimmy
fixed bridge, gauge strings, neck angle
Double Edge Problem aerocol Pickups & wiring 4 06-28-2004 10:26 PM
JCM2000 DSL100 volume swell problem Joshka Gear and Equipment 40 04-14-2004 06:49 AM
please post your funniest sounding guitar problem latinjem7vwh Tech: Setup, Repairs and Mods 10 02-25-2003 02:03 PM
Problem with the neck of JEM10 heiko78 JEM and Universe Guitars 2 10-12-2002 05:44 PM
Input Jack - ... anyone else got this problem? Fabe Tech: Setup, Repairs and Mods 0 03-28-2002 07:29 AM
