Re: headstock decal clear over question
what kind of decal? water slide or vinyl? Spray your clear on. That will hide the clear part of the decal if you are using a water slide. Put your decal on. Spray several coats over the top of the decal. If it is vinyl, you'll need a lot of coverage to make it smooth. When it cures, wet sand it so you get it smooth, buff it and your done
