Old 06-06-2008, 01:37 AM
Rachmaninoff  is offline
Posts: 567  -  iTrader: (0)
Images: 5
Reviews: 11
Question
Help, action high at 5th fret, low at 19th fret
So that's it.
Action is high around 5th fret and good around 19th fret.
If I low the trem, I get lots of buzzing, and the action around 5th fret is still high.
Guitar is Universe UV7BK.
Any thoughts?
Old 06-06-2008, 02:22 AM
waylay00  is offline
Posts: 3,763  -  iTrader: (10)
Re: Help, action high at 5th fret, low at 19th fret
Have you tried adjusting the truss rod?
Old 06-06-2008, 02:24 AM
jazzedout  is offline
Posts: 671  -  iTrader: (5)
My first guess is that there is more neck bow than needed. On the low B string press the first fret and with your other hand press behind the 24th fret (i.e. above the pickup). You should see just a little clearance above the 7th fret.
For more info see the tech description here:
Step 3: Neck Bow - Truss Rod adjustment
http://www.jemsite.com/tech/1setup.htm#step3
Old 06-06-2008, 12:03 PM
kspeed  is offline
Posts: 215  -  iTrader: (0)
Sounds like Jazzedout is right - too much neck bow plus the bridge may be too low. Check for any shims under the nut, you might have too many.
action high uv7bk, neck bow, rod adjustment
Buzzing on the first fret, high e jeffrg270 Tech: Setup, Repairs and Mods 3 02-06-2005 02:44 PM
high action or just me? marshall JEM and Universe Guitars 4 12-16-2003 08:38 AM
The string's action is high, how can I low it? Addicted To Guitar Tech: Setup, Repairs and Mods 2 08-11-2002 08:10 AM
Just got a new Jem, have a high fret - What to do? Triangle Tech: Setup, Repairs and Mods 8 08-14-2001 06:15 PM
Strange JPM reaction - trem too high? pups too high? julio Tech: Setup, Repairs and Mods 7 08-07-2001 07:39 PM
