Tech: Setup, Repairs and Mods
help adjusting bridge
10-16-2007, 02:20 AM
bigred
Posts: 6 - iTrader: (
hi, for some reason my
tremolo arm
always hits the tip of the 5 way switch, this is an edge tremolo, i have it set up correctly (I think), when i lower the action is when the arm hits the tip of the switch on position 3 all the time and sometimes on the in between spots. I cant seem to fix this, my other guitars dont have this problem and with those i can go down super low. Give me some tips please.
bigred
Find all posts by bigred
10-16-2007, 02:25 AM
reguv760
Posts: 1,197 - iTrader: (
Reviews: 12
Re: help adjusting bridge
did ya check the
bridge angle
? that's usually the issue...
Reg
reguv760
Visit reguv760's homepage!
Find all posts by reguv760
10-16-2007, 02:36 AM
bigred
hey, well the angle of the bridge is just like the guide thats posted on this site, the marker on the side of the bridge is parallel to the body of the guitar, my other guitar is this way too but it doesnt have this problem, i bought this guitar second hand so im not sure if the studs are even correct ones. I think if i make it so that the tail sinks in more this will go away but that wont be the proper set up now. Is there anything else i should look for?
02:42 AM
bigred
10-16-2007, 03:08 AM
reguv760
Reviews: 12
hmmm... if its not that, maybe the switch tip / switch have been replaced?
Reg
reguv760
10-16-2007, 09:42 AM
bigred
thanks but its not the tip, i removed 2 others from my other rg's just to test them and they are all the same size.
bigred
10-16-2007, 10:10 AM
Dee
Posts: 8,514 - iTrader: (
I had the same problem on my RG 20th. I had to set the baseplate slightly more tilted back than usual, but actually it's fine, it doesn't look or feel weird, just needed to tilt back a mm or two. I also fitted a new switch tip that's a little less pointy than the Ibanez ones (they are very pointy!).
Had I used a
neck shim
and raised the bridge to compensate, that would have done the trick, but I hate using shims. I like 100% wood to wood contact in this area.
Dee
Find all posts by Dee
10-16-2007, 10:51 AM
bigred
ok cool so i will tilt it back a bit and see what happens, by the way was that a switch tip from a stratocaster you used? I know mines has 1 shim installed, I wonder if this is common among rg 20th or vintage 5 series.
bigred
10-16-2007, 11:27 AM
Dee
I had a spare switch tip in a box of parts and it fit perfectly. I'm not sure where it's originally from, but the top of it is quite rounded and the whole thing is shorter than the standard Ibanez ones.
As for shims, I've had several Ibanez with them and several without. I usually take them out anyway.
02:27 PM
Dee
10-16-2007, 11:49 AM
jb4674
Posts: 4,010 - iTrader: (
Reviews: 6
Take a picture..............
Jimmy:smile
jb4674
Find all posts by jb4674
10-17-2007, 12:40 AM
bigred
thanks for the help got it fixed, i poped the trem out and i started messing around with the sleeve( i think thats what its called) it was kinda loose i tightened it up a bit and dropped the arm back in, tuned up and now it doesnt hit the tip no matter what position. Im still gonna hunt down one of those lil ones. Thanks.
bigred
bridge angle
edge trem
neck shim
tremolo arm
how do u measure a bridge
which ibanez bridge is the best
guitar white hardware bridge
WHAT HUMBUCKER BEST FOR STRAT BRIDGE
where to place sympathetic bridge
Installing peizos into an edge pro bridge.
merman_93
12:15 PM
Bridge grounding issue on RGA121
Vinco
Pickups & wiring
10:00 AM
Breed neck / bridge difference in bridge position
marino
Pickups & wiring
09:43 PM
Is this going to be easy??? - Bridge replacement for RG421
ChrisReedSmith
09:25 AM
New P'ups in my JEM - ...bridge and middle replaced...
kennydoe
11:55 PM
07:46 AM
