Tech: Setup, Repairs and Mods
Help! EMGs won't fit in pickguard / scratchplate
11-02-2008, 08:40 AM
MT01
Posts: 39 - iTrader: (
I've just tried replacing the stock pickups in my RG550LTD with
EMG
81/85 and it has come to my attention that the 81 will not fit in the bridge pickup aperture on the
scratchplate
For now I've managed to fit the slightly smaller 85 in to the bridge, and I've squeezed the 81 into the neck position, however I'm not keen on the sound of the pickups in those positions.
How can I fit the 81 in the bridge?
Thanks
MT01
Find all posts by MT01
11-02-2008, 08:45 AM
Algiman
Posts: 2,553 - iTrader: (
Re: Help! EMGs won't fit in pickguard / scratchplate
Er, make the hole in the scratchplate bigger?
Algiman
Find all posts by Algiman
11-02-2008, 08:47 AM
MT01
Algiman
That would be the logical conclusion, but how exactly?
MT01
11-02-2008, 08:51 AM
CosmicDebris
Posts: 3,217 - iTrader: (
Blowtorch would usually do the trick. If you don't have one of those use something to file it away at the needed place. I like fire so I usually use a torch.
CosmicDebris
Find all posts by CosmicDebris
11-02-2008, 08:53 AM
MT01
CosmicDebris
I have a World War II flame thrower. Would that work?
MT01
11-02-2008, 08:54 AM
Algiman
I would think from your description that you only need to make the hole a tiny bit bigger, so no need to go and get new tools: I would use fine sand paper and a small block of wood and take off a small amount of plastic at a time. Find something round that is the right diameter for the corners. Secret is to go slow and to support the edge that you are working on while you sand.
Algiman
11-02-2008, 08:55 AM
Algiman
A flame thrower would be a lot more fun though!
Algiman
CosmicDebris
MT01
Yes but distance to object is critical.
CosmicDebris
11-03-2008, 09:52 AM
buddroyce
Posts: 1,914 - iTrader: (
Sandpaper works but I find a razor blade to scrape the sides equally as effective and usually quicker.
buddroyce
Visit buddroyce's homepage!
Find all posts by buddroyce
11-03-2008, 05:30 PM
Foulacy
Posts: 354 - iTrader: (
metal wood file and fine grit sand paper to smooth it off
Foulacy
Find all posts by Foulacy
11-04-2008, 03:17 PM
MT01
Should the fact that it's a mirrored scratchplate make any difference?
MT01
11-05-2008, 03:07 PM
MT01
Job done in 5 minutes with a flat and round file. It only needed very slight filing.
It seems I was overly paranoid about destroying the scratchplate!
Thanks for your advice.
MT01
11-05-2008, 04:22 PM
callen3615
Posts: 1,412 - iTrader: (
CosmicDebris
FIRE!!!!
callen3615
Find all posts by callen3615
emg
pickguard
scratchplate
what screws to use when installing a pickguard
emgs are the best
how to route for emgs 707
how do I get a pickguard like the one on the wayne static EX
how to install emgs!
7vwh scratchplate
projectjem
07:52 PM
Scratchplate problem..
GuitarAkuma
03:30 AM
Scratchplate ideas?
Bezial
05:04 AM
Where can I get a clear scratchplate?
wallopwallop
03:22 PM
Scratchplate Collages
wallopwallop
05:18 AM
02:00 PM
