Tech: Setup, Repairs and Mods
HELP! I cannot untighten the internal pivot post screws.....
06-01-2009, 04:28 PM
Max Dread
Posts: 105 - iTrader: (
.....on my lo-pro Edge. They are completely locked tight and until I untighten them I can't adjust my guitars action.
Any tips or suggestions would be great.....
Cheers
Max
Max Dread
Find all posts by Max Dread
06-01-2009, 04:32 PM
Posts: 19,353 - iTrader: (
Re: HELP! I cannot untighten the internal pivot post screws.....
Always loosen the stud, never the
set screw
06-01-2009, 04:41 PM
Max Dread
As coicidence would have it I am currently (re)ploughing through the Ibanez Rules Tech section - an invaluable, fantastic and muchly appreciated resource!!!
That aside, even after having loosened the stud, I still cannot "unlock" the linernal lock screw!
Max Dread
06-01-2009, 04:49 PM
you sure it was tightened to begin with?
Otherwise, pull the stud out to investigate.
06-03-2009, 05:50 AM
moonlight
Posts: 353 - iTrader: (
Might try a small drop of penetrating oil and heat the stud up,not too hot, with a small tip soldering iron.
moonlight
Find all posts by moonlight
06-03-2009, 06:24 AM
Max Dread
Good idea, and thanks for the suggestion......
I did try a little oil in there to see if that would help free things up, but no luck there.
I think I'll take the
bridge
off, remove the whole pivot posts, and try to see what's going on from there. If for whatever reason I still cannot get them apart, I'll get out the soldering iron and give this a go!
Max Dread
06-05-2009, 10:28 PM
moonlight
Ya,the oil and heat thing will only work if it is stuck from not being turned for a long time or a little rust. It could be that the treads are galled or maybe the locking screw is bent. I sometimes wonder how many people don't know about the locking studs and damage one of the parts by tightening down on it too hard.
moonlight
06-17-2009, 07:42 PM
JEM10th
Posts: 231 - iTrader: (
Tried loosening the locking screws inside the studs? Or are they the problem?
JEM10th
Find all posts by JEM10th
bridge
pivot post
set screw
trem
what screws to use when installing a pickguard
how to fix ibanez strap screws
what kind of screws are used on a floyd rose locking nut
how to solder ear post
Here is your chance to post your comments to Ibanez
Installing trem anchor bolts(pivot post).
mr.death
09:10 PM
Edge Pro Pivot Post Spacing?...
WERNER1
10:07 PM
Pivot Stud (Post) Spread of LoPro Edge-7
CrossingStar
08:42 AM
Where to find Edge bridge pivot screws?
Dee
07:56 PM
tool to remove the trem post set screws
schmintan
02:09 PM
12:43 PM
