Old 05-16-2006, 08:07 PM
Fretmelter  is offline
Posts: 3  -  iTrader: (0)
Unhappy
Help: low string goes abnormally sharp when picked
I play in a band that uses drop C# tuning, and am having problems with the low E (C#) string. Every time I pick the string it goes abnormally sharp (20-30 cents) before returning to its correct pitch. The guitar is an ibanez prestige, with a 50-gauge string for the low C#. On my ibanez jem10, I have a 46-guage string on the low C# and the note plays much less sharp after immediately picking. I would think the thicker gauge string would vibrate less sharp at the same pitch due to increased string tension.
Could it be from a better neck or setup, such as the nut? My Jem10 was setup by Rich Harris (who has done the best setup I have ever played on), but I have had 2 other techs look at the prestige and neither fixed it right. Does anyone have an answer for what causes abnormal sharpness to a plucked string?
Old 05-21-2006, 08:57 AM
rainonthegrave  is offline
Posts: 14  -  iTrader: (0)
Re: Help: low string goes abnormally sharp when picked
did u set the innotation???
Old 05-21-2006, 09:38 AM
Rotti  is offline
Posts: 3,341  -  iTrader: (8)
I'm thinking intonation or high action.
Old 05-21-2006, 05:17 PM
I paid to have the intonation and action setup, so I'm not sure. The action is pretty good actually, so I wouldnt think it would be the problem.
Old 05-22-2006, 02:52 AM
NaHuELoidE  is offline
Posts: 58  -  iTrader: (0)
make sure your technique is ok, i mean, not pressing the string so strong, or maybe, you should look at your picking hand: in my 7 string I had .52 for low A, and depending the attack it went sharp. now i use .11 gauge strings ( a whole tone drop) and dont have that problem at all now. maybe you should try heavier gauges
Old 05-22-2006, 03:16 AM
Well, I know that I definitely play harder live then when sitting at home, but it still seems puzzling. I will have to ask Rich Harris since he set up my Jem10 and it plays wonderfully at the same tuning with lighter gauge strings
gauge strings, ibanez jem, string tension
Yet another poorly mixed song by your truly IbanezroadstarII Multimedia: Music, Pictures & Sounds 33 03-16-2006 10:01 PM
7 string questions Ironical Communion JEM and Universe Guitars 16 12-18-2005 12:51 AM
MyHELP lack of good string muting is KILLLING ME!! - Fret ha Triangle Guitar Lessons & Music Theory 3 05-31-2005 08:57 AM
High E string fine tuner will not go sharp (Help please) mikeyCOA JS (Satriani Model) Ibanez Guitars 4 10-17-2004 01:57 PM
7 string tunigs christianc Other 7-string Guitars 20 10-11-2002 02:18 PM
