Old 05-10-2003, 11:32 AM
Entropy  is offline
Posts: 231  -  iTrader: (1)
Help on removing trem post inserts
What is the best way to remove the trem post inserts from a body?
I believe they are press fit in the body so I assume some sort of brute force method is needed.
Any help or suggestions are appreciated! thanks.
Old 05-10-2003, 01:02 PM
Rich  is offline
Why are you pulling them?
Whatever the reason, I use a cats paw. Lay some shims across the body to use as a base and protect the finish [I actually put the shims on top of a cloth] and then just pull them straight up. You'll have to cut away all the paint that covers the top edge of the inserts or you'll rip a bunch of it up, alot more than if you trim it around the insert.
Old 05-11-2003, 09:51 AM
Entropy  is offline
Thanks, Rich.
The reason I'm thinking about doing it is that in one hand I have a body with no hardware and in the other hand I have a full guitar to cannabilize for it's hardware.
