Old 06-22-2008, 10:59 PM
jbandy10  is offline
Posts: 139  -  iTrader: (0)
Help! RG550 pickup selector crackling!
Hey guys. A lot of times when I switch between the EMG's on my RG550, the signal will crackle a noticeable amount. It's usually when I switch to the bridge pickup.
It's a fairly old switch. The EMG's were installed a few years ago.
Do I just have a bad switch? I opened up the pickguard and all the connections looked good, but it still does it. Should I WD-40 it or what? Perhaps it needs replacing?
Old 06-22-2008, 11:22 PM
elcid  is offline
Posts: 8,720  -  iTrader: (12)
Re: Help! RG550 pickup selector crackling!
Just replace it.
Old 06-23-2008, 10:31 AM
ScottB  is offline
Posts: 2,208  -  iTrader: (12)
Images: 8
Do not use WD-40 on electronics unless you're trying to dry them out from being wet.
Old 06-23-2008, 10:38 AM
jbandy10  is offline
Yeah I always forget that. I might just go buy some contact cleaner from radio shack today.
Old 06-23-2008, 12:02 PM
HDS  is offline
Posts: 1,237  -  iTrader: (7)
Get some contact cleaner. Open the switch up and clean her out.
Old 06-23-2008, 12:29 PM
jbandy10  is offline
I just replaced it with a spare I had lying around. It was already really old and I figured it would be needed eventually anyway. All is well now.
pickup selector problem rob777vdy Tech: Setup, Repairs and Mods 2 05-03-2008 01:58 PM
Pickup selector options? Fang Tech: Setup, Repairs and Mods 1 01-28-2008 05:37 AM
Rotary Pickup selector elcid Pickups & wiring 2 02-15-2007 11:32 PM
Pickup selector noise help dan321 Tech: Setup, Repairs and Mods 0 11-08-2006 04:56 PM
Pickup selector Beavis Pickups & wiring 3 06-09-2002 05:37 AM
