Old 08-31-2005, 03:15 AM
sugizo_esp  is offline
Posts: 446  -  iTrader: (0)
HELP!..tip of lead stuck inside the amp
hey..everyone
i need desperate help
i have the tip of the guitar lead broken off and its stuck inside the guitar amp
s input jack...
is there any way of gettting that out???
its a small 15W peavey amp
thx
Old 08-31-2005, 06:42 AM
Dr. Funkenstein  is offline
Posts: 115  -  iTrader: (0)
Re: HELP!..tip of lead stuck inside the amp
superglue something to the tip and then yank it out....
Old 08-31-2005, 08:42 AM
unfortunately..the left over cable wouldnt fit back in
does it mean i have to pull apart the amp to get that piece of crap out?!
Old 08-31-2005, 09:15 AM
pawel  is offline
Posts: 2,656  -  iTrader: (3)
I think Dr. Funkenstein meant to just glue anything to the tip of the cable, not necessarily the actual leftover cable, anything that fits, a metal rod, a pen, anything.
I think this is a good time to start buying better cables ;-)
Old 08-31-2005, 10:02 AM
i m still searching for sumthing that fits
Old 08-31-2005, 11:42 AM
Algiman  is offline
Posts: 2,553  -  iTrader: (14)
What's wrong with pulling the amp apart?
Old 08-31-2005, 12:04 PM
pawel  is offline
Putting it back together
Old 08-31-2005, 12:51 PM
Algiman  is offline
lol
Old 09-01-2005, 09:07 AM
superhairycamel  is offline
Posts: 338  -  iTrader: (0)
hahahahahhaha/\
Old 09-01-2005, 01:40 PM
timi_h  is offline
Posts: 1,104  -  iTrader: (0)
what do u mean nothin that fits?!?!?!? u tellin me u dont own a set of allen keys? a set of mini screwdrivers?!?!?!?
Old 09-01-2005, 01:48 PM
i tried pulling it apart ...but after unscrewing it..it feels theres sumthign holding it together..and i jsut cant pull it apart..
Old 09-01-2005, 02:03 PM
JJEMMER777  is offline
Posts: 8,374  -  iTrader: (5)
Dude, you cant find something to fit in there??? Your making this way too difficult. Just get some good epoxy or try superglue (dont be messy) LEt it dry and pull the thing out. Do you have an allen wrech set? There has to be something laying around the house that will fit. Use your MacGyver instinct Do you have a metal coat hanger??? Use some wire cutters and cut it into shape (just like a poker for a b*ong Make sure you just put a little glue only on the tip.
Let the glue dry and....bingo... pull it out.
I wouldn't suggest pulling the amp apart if you dont know what you are doing...and...Please make sure you at least unplug it before you try
Old 09-02-2005, 01:52 PM
i m just worry that the glue method will get messy...
Old 09-02-2005, 05:48 PM
sanitarium  is offline
Posts: 624  -  iTrader: (0)
there's nothing like glueing a couple of fingers togeather, don't worry just go for it. Ok so maybe if you glue your hand to the amp you got problems.....
Old 09-02-2005, 05:52 PM
Would you rather buy a new amp Just use a LITTLE glue, you should be fine.
peavey amp
5150 with boost pedal good for lead work? Jupiter Gear and Equipment 26 02-08-2004 09:36 PM
Recording... - Lead tones good, rythm tones bad? Kremlin Gear and Equipment 2 04-21-2002 03:46 PM
Stuck in a rut - If only I WANTED to sound like Yngwie Kremlin Guitar Lessons & Music Theory 20 09-01-2001 06:34 AM
Lead Boost with an EQ pedal - What are your settings? revsharp777 Gear and Equipment 2 07-30-2001 02:14 PM
Lead vs. Rythm kirk Gear and Equipment 18 03-12-2001 07:22 PM
