Old 04-15-2001, 12:12 PM
cowcowcow  is offline
Posts: 289  -  iTrader: (0)
Help......what happen to my fretboard? - breaking?.....why?
see..........
why is my fretboard having this problem?:help:
Old 04-15-2001, 12:20 PM
jemsite  is offline
Administrator
Posts: 9,271  -  iTrader: (5)
Images: 11
What exactly is the problem? that pic is a bit small to see alot of detail... glen
Old 04-15-2001, 12:41 PM
tomizm  is offline
Posts: 417  -  iTrader: (1)
yea, what he said.....
Old 04-15-2001, 02:08 PM
the LOW E part of the fretboard which the nut and the board are touching has broken a bit...
Old 04-15-2001, 02:18 PM
Rich  is online
Posts: 19,353  -  iTrader: (21)
Ouch, looks like some of the ebony has come off. Is that a PGM90?
Old 04-15-2001, 04:42 PM
yes.....
ahh.....this pic didn't show that part...
Old 04-15-2001, 04:50 PM
Rich  is online
I blew the first pic up, you can see it better from that angle. I can't tell you why/how it's doing it though.
Old 04-15-2001, 09:13 PM
Alinde  is offline
Posts: 8  -  iTrader: (0)
Hey cow,
From what I understand a chip came of the ebony. Do you still have that piece? If so you can glue it back carefully with superglue, and sand it back with fine sanding paper. Afterwards if you put some lemon oil on it, you'll never see that it's repaired.
If you don't have the chip anymore, you could fill it up with ebony powder or other black powder, and put a little drop of superglue to it. This will make it look very messy, but again you can use some fine sanding paper to get it right again.
Note: when you use the sanding paper, use it in the direction of the wood. Otherwise you'll see scrathes.
I hope this could help you a bit.
Good luck,
Alex
Old 04-15-2001, 09:57 PM
jemsite  is offline
Administrator
Images: 11
i don't see a chip, but a hi-res photo taken outdoors would greatly help
That said, it sounds like the edge of the fretboard has a small chip where the nut was sanded. It is common to do this, if you run a file horizontally across the fretboard, the grain of wood can chip. Again, i don't see a chip and prefer not to guess at a problem. If the "chip" is not near fret-1 then you have nothing to worry about, cosmetics aside. Good luck... glen
Old 04-16-2001, 01:00 AM
frankfalbo  is offline
Did you buy it like that, or did it happen after you had it? Fretboard blanks are rough shaped on belt sanders, then fine sanded by hand. Yours is beautifully fine sanded, but looks like in that section, the job didn't quite get done. I have seen it on the ends-by the nut or the highest frets. When they level the fretboard it is easy to be careless on the end. If it happened after you got the guitar, then it is probably a chip, and can be filled. But althought the pics are great, they don't clearly show the actual damage. Try with the strings off, on a sharper angle with the light showing shadows on that spot. Then we can tell you for certain.
