Tech: Setup, Repairs and Mods
Help with fixed bridge?
11-30-2007, 04:25 PM
indonez
Posts: 6 - iTrader: (
Hi all. I have an RG321 (no groans, please, I know its not the DNA). I'd like to replace the bridge on it. The guitar is string-thru body, which I really like, so I was hoping to find a compatible bridge that will still allow me to use that feature. One of the reasons I want to change the bridge is that I tune the thing down to C standard, which is messing with the intonation a bit, and I'd like to have a bridge with a little more saddle travel so that I can get the intonation right. Does anyone have any suggestions for a
fixed bridge
that would suit? I don't know much about brands or models of after-market accessories. I'd really appreciate any advice you guys have to offer.
indonez
Find all posts by indonez
11-30-2007, 05:11 PM
ColinMmmmm
Posts: 1,068 - iTrader: (
Re: Help with fixed bridge?
It seems bizarre that the current bridge doesn't allow proper intonation . . .
ColinMmmmm
Find all posts by ColinMmmmm
11-30-2007, 06:06 PM
indonez
I have the low "E" cranked as far as it will go to the point where the spring is eating itself. I think the bridge placement could have been a little better. It's not exactly at a right angle, and it's a junk bridge to start with. I just have no idea what to put in its place.
indonez
11-30-2007, 06:37 PM
indonez
It just kind of dawned on me that most of you have Floyds. This is probably the wrong forum to be asking such a question.
indonez
11-30-2007, 08:05 PM
brothersnowgone
Posts: 1,498 - iTrader: (
Reviews: 7
Try taking the spring off the low-e saddle and you might be able to tighten it enough for proper intonation. Just cause we have floyds doesn't mean with have no
hardtail bridge
guitars....
brothersnowgone
11-30-2007, 08:32 PM
ColinMmmmm
Yeah true many people here have hardtails. I'm wondering if you could do something like adjust the trussrod and/or saddle height to make things a bit easier. It's possible the factory set-up was not up to par, and you're having trouble intonating because of it. I mean I'm sure you can rustle up a bridge that would work, though it might not line up with the holes in the body you've got. I'm just trying to think of easier solutions than replacing the bridge.
ColinMmmmm
11-30-2007, 08:55 PM
jkahrs
Posts: 477 - iTrader: (
Just cut the spring. I've had to do it before myself. It's no big deal, and will take care of the problem. --Jason
jkahrs
Find all posts by jkahrs
11-30-2007, 11:18 PM
ColinMmmmm
What
gauge strings
do you have on there?
ColinMmmmm
12-04-2007, 01:29 PM
indonez
12 to 68
indonez
indonez
.012 to 68
indonez
12-04-2007, 04:17 PM
wilch
Posts: 1,783 - iTrader: (
Hi there, alot of us here have hard tails too.
I have an RG421 (jap version of the 321)... pretty much EXACTLY the same, body wood is different though I think. The 321 having the nicer mahogony.
Very strange that you can't intonate for C tuning with the standard bridge... You should be able to. Maybe put the saddles back to neutral and start again?
wilch
Visit wilch's homepage!
Find all posts by wilch
12-04-2007, 04:38 PM
ScottB
Posts: 2,208 - iTrader: (
Hipshot
makes some of the finest hardtails and strat hardware available.
ScottB
Visit ScottB's homepage!
Find all posts by ScottB
12-04-2007, 05:14 PM
Vinco
Posts: 234 - iTrader: (
Difficult intonation sometimes comes from...flat nut slots!
The string can in some case have "floating" support point because there is not enough slot angle.
I experienced this case on an RGA121, not really the cheapest Ibanez...
I went through the process of removing springs, etc. But the problem disappeared after I changed the nut (some graphtech's are perfect for Ibanez).
I had the idea to check that after reading a "build your own guitar in 10 easy steps" kind of book where the author mentionned that cutting flat nut slots could simply completely ruin intonation of the guitar.
Vinco
Find all posts by Vinco
12-05-2007, 09:44 AM
djohns74
Posts: 580 - iTrader: (
indonez
.012 to 68
Wow, that's an extremely heavy bottom string, even for C Standard, which might be part of the problem.
Anyway, I put one of
these
on my RG320-RG321 conversion project with a string-through setup and I have no complaints at all with it.
djohns74
Find all posts by djohns74
fixed bridge
gauge strings
hardtail bridge
how to setup a fixed bridge ibanez
how do u measure a bridge
guitar white hardware bridge
WHAT HUMBUCKER BEST FOR STRAT BRIDGE
where to place sympathetic bridge
warmoth fixed 7string bridge
chi
01:48 AM
[FS] Ibanez JS-6 Joe Satriani ( Mahogany Body / Fixed Bridge )
Sleazy
12:33 PM
FS:RG 7421 fixed bridge Black with JB/Jazz 7 pickups
AllShallPerish
02:18 PM
Why limit fixed bridge RG's to Japan?
PekkaM
Comments to Ibanez
01:16 PM
LR Baggs X-bridge - Fixed bridge
cowcowcow
02:02 PM
06:09 AM
