Old 12-03-2007, 11:41 AM
narmo  is offline
Posts: 11  -  iTrader: (0)
Post
Help with stiff rg550 neck?
Hi,
my rg550 neck wont concave as I would like it to. The bolt is all loose but the strings dont pull enough to make the neck concave. It is just flat.
Is there something I can do to make the neck behave(not taking account filing the neck concave, luthiers neck heat-treatment or neck shimming)?
Also, i wonder if putting some 060-013 strings on the guitar would hurt the Edge knife edges? (I feel pretty stupid with this question)
Narmo
Old 12-03-2007, 01:31 PM
Martyr Machine  is offline
Posts: 340  -  iTrader: (1)
Re: Help with stiff rg550 neck?
That's a truss rod issue. I'm sure there's an FAQ somewhere on this site about truss rod adjustments.
Old 12-03-2007, 01:32 PM
jkahrs  is offline
Posts: 477  -  iTrader: (6)
Did you have the tremolo blocked before you started tuning it up? --Jason
Old 12-03-2007, 08:18 PM
ryanb  is offline
Posts: 1,457  -  iTrader: (0)
Is it flat or actually backbowed? If it is flat, you may be able to do fine with a careful setup and a flat neck. Otherwise, things start getting harder.
You can try putting some heavy strings on it and let it sit for a while. It might take some curve back and even hold it when you switch back to a light gauge. It's worth a try. Otherwise, since you don't have a dual-action truss rod, you are looking at something more complicated. A luthier with a neck jig could add the desired amount of relief into the frets ... or with some more work out of the fretboard, or heat treat the neck, etc. It gets more expensive as you go. Good luck.
Old 12-03-2007, 09:40 PM
brothersnowgone  is offline
Posts: 1,498  -  iTrader: (3)
Reviews: 7
I haven't found a gauge yet that will damage the knife edges....
Old 12-04-2007, 07:42 AM
narmo  is offline
thank you for replies, I'll try to apply some serious string tension to this guitar hehe
narmo
neck shim, rod adjustment, string tension, truss rod, truss rod adjustment, truss rod adjustments
E-Bay Seller Hippo_House Neck Review PatrickSimsCustomShopUSA Vendors, Auction & Reseller Talk 17 02-18-2007 05:22 PM
RG550 neck pocket Dave67 Other Ibanez Guitars (including Premiums) 12 02-03-2007 10:58 AM
WTB: Ibanez RG550 neck non-AANJ JiMoSiTY Classified Ads: Guitars and Gear 0 05-22-2005 01:15 PM
FS RG550 body & neck, RG570 neck & misc screamndemon69 Classified Ads: Guitars and Gear 1 05-07-2005 01:58 PM
cutting an original neck to become an all access neck Zeroleet Tech: Setup, Repairs and Mods 32 05-05-2005 10:08 AM
