Tech: Setup, Repairs and Mods
Help with tightening arm holder/removing trem... i'm scared!
05-22-2004, 06:25 PM
ddk
Posts: 6 - iTrader: (
Hi all,
I have been playing
Ibanez guitars
equipped with
Edge trems
for 15 years and have NEVER heard of tightening the arm holder until I did a jemsite search. So THANK YOU! I have been putting up with loose, jiggly bars this whole time, and I want to fix it, because they PISS ME OFF!!
I have read through the instructions at
http://jemsite.com/tech/t_3other.htm#tremarmholder
and
http://www.ibanezrules.com/tech/setup/loose_holder.htm
but there are several points I wanted to clarify before diving in.
The jemsite directions seemed to point towards performing the repair with a deep socket wrench and screwdriver with the trem in place, while the ibanezrules site recommends removing the trem and using a 10mm wrench and "channel lock" pliers. Any recommendations for using one method over the other?
As far as tools needed, I have a 10mm wrench, but do not know what channel lock pliers are. I did a google search, and am getting confused because apparently there is a BRAND of pliers with the name "channel lock." Can anyone clarify what specific tool(s) I should be looking for?
THANK YOU!
ddk
Find all posts by ddk
05-22-2004, 06:46 PM
Posts: 19,352 - iTrader: (
If it's Channel Lock brand they call them tongue and groove pliers, which used to just be universally known as channel lock
http://www.coastaltool.com/cgi-bin/S...608+1085303389
You can't get the
arm holder
really tight using a screwdriver from the top, and you will marr then arm holder trying to, and possibly slip and do something much worse to the top. [of course Glen will tell you different]. I prefer the safe method which guarantees it'll be the only time you'll ever have to do it
05-22-2004, 07:04 PM
jemsite
Administrator
Posts: 9,271 - iTrader: (
if you're sloppy or in doubt, then remove the trem.
I've done this 17 years now w/o slipping
... glen
ps - you don't tighten w/ the screwdriver (as rich is implying)... you tighten from below, w/ the socket wrench simply using the flat screwdriver to keep counterpressure. idiotproof is what i'd call it
jemsite
Find all posts by jemsite
05-22-2004, 07:27 PM
When the holder itself is loose it itself needs to be tightened before the nut is tightened. If you're not tightening the holder first then it'll never be tight and no wonder you've been doing it for 17 years
05-22-2004, 08:17 PM
jemsite
Administrator
thanks captain obvious.
you lightly screw the arm holder into the baseplate where only a total klutz would scrape/scratch/slip... just snug (not with powertools). the holder is held firm w/ pressure from the nut below (which gets tightened)... glen
jemsite
05-22-2004, 10:49 PM
Repeating, if you don't **tighten** the holder first it will never be/stay *tight*
05-22-2004, 10:57 PM
jemsite
Administrator
your reading comprehension is at a low point today
...glen
jemsite
05-22-2004, 11:32 PM
jemsite
... just snug
Actually it would be yours, snug is not tight
05-23-2004, 12:03 AM
jemsite
Administrator
snug is not loose...
Main Entry: 1snug
Pronunciation: 'sn&g
Function: verb
Inflected Form(s): snugged; snug·ging
Etymology: 2snug
intransitive senses : SNUGGLE
transitive senses
1 : to cause to fit closely
2 : to make snug
3 : HIDE
4 : to secure by fastening or lashing down
jemsite
05-23-2004, 01:18 AM
snug is also not TIGHT. If it's not tight it will eventualy work loose again. Maybe not for you since you've preferred hardtails over floaters for how long now. But serious whammy users will loosen that holder back up again if it's not TIGHT to begin with, especially if they like a stiff bar!
05-23-2004, 06:08 AM
Al M
Posts: 551 - iTrader: (
Hehehehehehe, you two are so funny
Al M
Find all posts by Al M
05-23-2004, 10:16 AM
lewis_ho
Posts: 42 - iTrader: (
A search at
www.dictionary.com
Synonyms for snug: close, comfortable, comfy, compact, convenient, cushy, easeful, easy, homelike, homely, intimate, neat, restful, sheltered, soft, substantial,
tight
, trim, warm, well-off.
Sorry had nothing to do Rich.
lewis_ho
Find all posts by lewis_ho
05-23-2004, 11:21 AM
Vladdrac
Posts: 139 - iTrader: (
Al M
Vladdrac
Find all posts by Vladdrac
05-23-2004, 01:42 PM
MicJustMic
Posts: 931 - iTrader: (
I'm so "Vai-olent" with my trem no matter how "snug" or "tight" or what method I use to tighten it (I use both depending on if I feel like taking the time to pull the trem or not), it still comes loose.
I've resorted to Loc-tite, keeps the thing solid and still easy to remove if needed.
I almost Krazy-Glued the thing once I was so frustrated, but common sense kicked in . . . if I did that I'd be buying a whole new bridge instead of an arm holder if the holder ever breaks.
Mic
MicJustMic
Visit MicJustMic's homepage!
Find all posts by MicJustMic
05-23-2004, 02:42 PM
ddk
AHHHHHHHHH DAAAAAAAAMMMMNNNNN
hey guys,
thanks for the tips! although it sounds like there isn't a clear consensus as to which method is best.
i have another problem.
i removed the trem and tried tightening the nut. but in an attempt to make it REALLY tight, i twisted the arm holder clear off. so now it is in two pieces. DON'T LAUGH!!
how much does this part cost to replace? and HOW do i replace it?
please help! Thank you!
ddk
arm holder
edge trem
edge trems
ibanez guitars
what trem is on the rusty cooley
how to tighten zr trem
How to block ibanez trem
how to narrow the fingerboard without removing it
is my edge trem bar in all the way
09:46 AM
