Tech: Setup, Repairs and Mods
High E string action problem
02-05-2004, 10:23 AM
John
Posts: 42 - iTrader: (
Hello,
I have a '03 Jem 7VWH, I changed the strings not long ago and noticed that the E string is a little bit higher than it should be. Nothing dramatic but it's pretty annoying, and as it's supposedly impossible to set the action for each string individually, I don't know what the hell I should do.
Any help would be really appreciated.
Cheers
John
Find all posts by John
02-05-2004, 11:46 AM
MicJustMic
Posts: 931 - iTrader: (
Get yourself a soda can, wash it out really good and cut it into small bits that will match the shape of the saddles.
Shim the saddles to match, or to whatever is comfortable for you and you're all set.
NOTHING is impossible.
Well, don't try to fly without an airplane. :-)
Mic
MicJustMic
Visit MicJustMic's homepage!
Find all posts by MicJustMic
02-05-2004, 03:12 PM
Posts: 19,352 - iTrader: (
Or just buy some saddle shims
02-05-2004, 03:20 PM
MicJustMic
That too, but I think I read that you have the same problem with saddle shims as I do . . . often they are too thick, so I just go right to the soda can shims now. :-)
Mic
MicJustMic
02-05-2004, 03:24 PM
To get micro radiused just cut up .1mm nut shims, I'm just lazy
I think his radius is probably far enough off that regular shims would do the most good
Just make sure and check the intonation screw washer isn't under the saddle [if you happened to take it off]
02-05-2004, 03:29 PM
Texter
Posts: 839 - iTrader: (
Isn't the saddle height influenced by the fine tuners anymore with the
Edge Pros
Texter
Find all posts by Texter
02-05-2004, 03:34 PM
The saddle insert is in the immoveably nose of the saddle.
02-05-2004, 03:37 PM
MicJustMic
Texter
Isn't the saddle height influenced by the fine tuners anymore with the Edge Pros?
Um, unless your bridge is sticking so far out of the guitar that the break point of the string is at the lock block in the saddle, and not the string-seat of the saddle, the fine tuners will NEVER effect the action of the guitar.
Never did, never will . . . that's not what they are for.
Granted, they can effect the individual string action ever so slightly depending on how angled your bridge is, but not enough that you could ever notice it, we're talking about thousandths of a mm at that point of the saddle.
Mic
MicJustMic
02-06-2004, 01:08 AM
DirtyBird31
Posts: 226 - iTrader: (
I dunno if this is what they were talking about, but on Edges there is a small washer between the saddle and the top of the intonation/saddle lock screws. If this somehow got placed on the bottom of the saddle, it can cause this effect! Just change strings and check to make sure all your washers are in the right place.
DirtyBird31
Find all posts by DirtyBird31
02-06-2004, 08:30 AM
John
DirtyBird31
That's exactly what happened! Thanks a bunch!
John
02-06-2004, 08:33 AM
02-06-2004, 08:59 AM
John
I missed that part of your post last night. Thanks to all of you anyway. :P
And Rich, your site is really neat man. I've been going there for a while now, and I'm just about to print some of the tech stuff, my guitar won't stay in tune, I could use some of the info that's up there!
John
02-06-2004, 10:43 AM
Texter
MicJustMic
Mic
SO WTF DID I MENTION IT? DUH! It might just be a few tenths of a mm max but there's definitely a noticeable difference.
Texter
02-06-2004, 03:22 PM
Fry
Posts: 259 - iTrader: (
I think he is trying to say that it is not a noticeable difference.
Fry
Find all posts by Fry
02-07-2004, 01:14 AM
MicJustMic
Texter
MicJustMic
Mic
If you can feel one-one thousandth of a millimeter you have the most sensitive touch of any human that's ever lived.
MicJustMic
base plate
edge pros
fretboard radius
nut shim
the action is a medium/high setup
+bias +"when playing" +"high volumes"
guitar playing talent show high school
where to buy guitar string sin southampton
use a .016 for the 2nd string?
04:42 PM
