Old 05-02-2007, 09:04 PM
mike2558  is offline
Posts: 314  -  iTrader: (0)
high E string problem
Hi, it's been a while since I've posted here but I thought this would be a good place to ask about a recent problem with my JS1200. When I do a bend on the 15, 17 and 19th fret on the high E string it sounds all bad and isn't smooth like it should be. It makes sort of a wierd sound and then no more sound comes other than fuzziness. How do I solve this problem? Also, I'm pretty sure my strings are fully stretched but when I do crazy whammy bar tricks like satch does my low E, A strings go sharp and the D and B strings go flat. What's the dealio here? Thanks in advance for any help.
Old 05-02-2007, 11:51 PM
ET Guitars  is offline
Posts: 369  -  iTrader: (1)
Re: high E string problem
Sounds like you need some fret levelling, the fret in front of the one you are playing/bending is taller - just high enough to catch and muffle the note. Also there could be a bit of bow in the neck, or you may need a shim in the neck pocket to adjust the neck angle. These are more action-related things, so its most likely you just need a fret level.
fret level, neck angle
Edge pro High E string going out of tune. Stormcrow Tech: Setup, Repairs and Mods 1 09-21-2006 03:49 PM
high E string always gets loose rx JEM and Universe Guitars 12 05-07-2005 10:16 AM
High E String breaking! Adagio_777 Tech: Setup, Repairs and Mods 6 01-18-2005 09:08 AM
High E string fine tuner will not go sharp (Help please) mikeyCOA JS (Satriani Model) Ibanez Guitars 4 10-17-2004 01:57 PM
High E string fine tuner will not sharpen on JS1000 Help!!!! mikeyCOA Tech: Setup, Repairs and Mods 5 09-16-2004 07:08 PM
