Tech: Setup, Repairs and Mods
High nut, how to rectify?
05-30-2009, 02:24 PM
Random Hero
Posts: 55 - iTrader: (
You guys that have fixed a high nut, did you file the whole thing and basically make it sit deeper in the slot at the end of the fingerboard or did you get each slot filed down to allow each string to sit individually lower?
The nut is a 7 string locking nut, Lo-Pro 7, FWIW.
02:34 PM
Random Hero
Find all posts by Random Hero
05-30-2009, 02:34 PM
skins345669
Posts: 835 - iTrader: (
Re: High nut, how to rectify?
Can do either. File them down from the top, or take the nut out and file up from the bottom, if you see what I mean. I would recommend the second one; doing the first makes the strings liable to getting stuck which causes problem with tuning.
skins345669
Find all posts by skins345669
05-30-2009, 02:39 PM
Posts: 19,350 - iTrader: (
Are you sure you don't have far too much neck relief? A high 7 nut is pretty rare, the biggest problem with 7's is the radius mismatch to the first fret that you have to bend the nut to correct.
You could only file the wound string slots, the pads still have to be able to keep the strings locked, and you will quickly kill a nut file trying it to begin with.
05-30-2009, 04:27 PM
Random Hero
Fretting at the first and 15th, my neck is almost straight with slight relief.
Random Hero
05-30-2009, 04:37 PM
Jaden
Posts: 2,464 - iTrader: (
If its not what Rich says then I quite often remove material (wood) from beneath the nut simply by chiseling away a few thou at a time using the chisel like a plane and making sure I keep the nut platform flat... which is pretty important.
I dont know if I would recommend anyone to do that though, my chisels are like razors and ive been wooworking/joining/working on guitars for nearly 20 years and its still a difficult job to do perfectly.
Jaden
Visit Jaden's homepage!
Find all posts by Jaden
05-30-2009, 05:11 PM
I used to take it out of the rout, but discovered grinding was 10 times faster, and didn't further weaken the thinnest part of the neck. Although, I'm not sure I'd recomend grinding to somebody that's never done it either
05-30-2009, 05:19 PM
Random Hero
I took a few pics to highlight the action at the nut and the rest of the neck to give you an idea.
Nut, with Jazz III for comparative purposes;
Low B at the 7th fret;
High E at the 12th;
12th;
24th (1);
24th (2);
Nut again;
Random Hero
05-30-2009, 06:45 PM
jb4674
Posts: 4,010 - iTrader: (
Reviews: 6
I'd say you should file the grooves like Rich suggested, instead of filing under the nut. As it looks like from the pictures, the action seems pretty low.
Jimmy
jb4674
Find all posts by jb4674
05-30-2009, 06:53 PM
Random Hero
jb4674
Jimmy
The action is actually very low. It's ~1mm at the 24th on the High E but it feels weird coming from a higher point at both ends rather than a lower nut... if that makes sense.
To crudely illustrate;
You would normally have a string angle like so... "/" (extreme angle, but I'm using standard characters here...) but you push it down to something like "___" yeah? It's more like "___" being pushed down to "\/".
Did that make sense sense to anybody?
Basically the action is very consistent all the way along, it just feels a bit weird coming from a higher nut.
Random Hero
05-31-2009, 12:18 AM
bammbamm
Posts: 4,134 - iTrader: (
Are there any shims under the nut?
Most ship with brass shims.
bammbamm
Visit bammbamm's homepage!
Find all posts by bammbamm
05-31-2009, 06:52 AM
axemanrio
Posts: 992 - iTrader: (
From one of the pics it looks like there's at least one shim. If you haven't already, remove the shim(s) and see if that gets you closer to what you want.
axemanrio
Visit axemanrio's homepage!
Find all posts by axemanrio
05-31-2009, 07:48 AM
Random Hero
bammbamm
axemanrio
Nope, no shims under there.
Random Hero
how high does joe satriani set his pickups
+bias +"when playing" +"high volumes"
guitar playing talent show high school
amalio burguet guitar has high action ?
how high pass filter works
My E's too high dog!
pushpin&poetry
46
07-06-2008
10:36 PM
High G!?
Roland
01:19 AM
What gives? One high..one low
Jeeks
11:52 PM
High A vs low B...
Alain
Other 7-string Guitars
29
02-16-2003
09:54 PM
Strange JPM reaction - trem too high? pups too high?
julio
07:39 PM
10:39 AM
