Tech: Setup, Repairs and Mods
Hollow body swirl
Page 2 of 3
06-09-2011, 08:26 AM
RGTFanatic
Posts: 6,096 - iTrader: (
Re: Hollow body swirl
I was wondering....... why not fill the body with sanding sealer, let it soak for a bit, then drain and let dry. You'd probably need some type of rotisserie for drying to keep the wet sealer from pooling.
also, instead of putting sand in the balloons, why not just use water?? It's obviously has the same density as the water your dipping in. If you have large enough balloons, they may seal the f-holes when full.
__________________
RGTFanatic
Visit RGTFanatic's homepage!
Find all posts by RGTFanatic
06-09-2011, 10:01 AM
mortenfaerestrand
Posts: 29 - iTrader: (
beerbohm
I'm trying to swirl a
custom
made hollowbody guitar. The guitar body is based off of an ibanez and a prs smith hollow body but it has an almost 90degree hockey stick headstock. The colors are red and black. I'm using the borax method, since the guitar is a thru-neck guitar I thought it'd be cool to dip the whole guitar since i haven't seen that yet. I filled the guitar with plastic bags then taped off the openings as best I could. I filled 90 gallons of water in a trash can heated it to 78 degrees and added 8 cups of borax stirred then let it sit. I mixed my paints and began to dip i suddenly realized that dipping a hollow guitar is incredibly difficult because it wants to float. I also found that dipping a whole guitar is impossible because the body wants to move violently around. The third thing that I found to cause this to be a problem was that water seeped into the tape causing air bubbles which pushed the paint away from the guitar. This caused the starting dip to work out as planned but once the paint went past the holes it faded to crap. Does any one have any ideas on what I can do to make this dip work. Thanks
hahaha, I wish you had filmed this!!! (sorry....) :-)
Morten
http://www.mortenslessons.com
mortenfaerestrand
Visit mortenfaerestrand's homepage!
Find all posts by mortenfaerestrand
06-12-2011, 11:25 PM
beerbohm
Posts: 78 - iTrader: (
It was the most epic fail i've ever had but i've learned alot so far. After this paint i'm on my 5th dip, hopefully 5 is the charm. I'm gonna try and post pics by tonight.
beerbohm
Find all posts by beerbohm
06-13-2011, 12:33 AM
beerbohm
beerbohm
06-13-2011, 12:43 AM
beerbohm
beerbohm
06-13-2011, 12:47 AM
AlaskaBat
Contributor
Posts: 8,948 - iTrader: (
Reviews: 98
Wow--that's more of a hockeystick headstock than any other hockeystick headstocks!
AlaskaBat
Find all posts by AlaskaBat
06-13-2011, 12:59 AM
beerbohm
It's gonna be all chrome with a jbj original seymour duncan with concentric pot for volume and tone all wired through the jack plate. It took some time to find a proper nut placement for optimum string angle with the neck but i've strung it all up and it seems to hold up fine. The Body is made of 3 different pieces of wood a solid back a hollow cavity inside and a solid top it could have the ability to have a tremolo I just don't have the funds. (I started to make this guitar from the first guitar that I've owned a "First Act" 50 dollar hunk of crap...I don't own a router of power saw or anything like that just a dremel a file and a drill I'm hoping to sell this that way I can afford to buy a few tools that way I can make some crazy looking guitars)
beerbohm
06-13-2011, 03:21 AM
beerbohm
fail #6
beerbohm
06-22-2011, 04:09 AM
beerbohm
beerbohm
06-22-2011, 04:11 AM
beerbohm
beerbohm
06-22-2011, 05:11 AM
The Euphor
Posts: 3,353 - iTrader: (
Awesome skull on the back of the headstock!
It looks great!
The Euphor
Find all posts by The Euphor
06-22-2011, 05:34 AM
beerbohm
Thx I was starting to get tired of seeing all the same swirls so Ima try some brand new stuff. I'm on my 9th swirl for the body and its almost got the pattern i'm looking for. 10 should be my lucky number. It's funny I can custom paint graphics on a guitar in 4 days flat but it's taken well over a month of dip after dip to barely come up with a satisfactory swirl.
beerbohm
06-22-2011, 06:54 AM
WillTubarao
Posts: 4,057 - iTrader: (
omg
is that skull really a random natural swirl or it's photoshopped?
awesomeness..........
WillTubarao
Visit WillTubarao's homepage!
Find all posts by WillTubarao
06-22-2011, 12:41 PM
beerbohm
i worked the pattern into the swirl with a paint brush and used a blob to my advantage
beerbohm
30
06-22-2011, 06:02 PM
beerbohm
The top left of it I dipped in the wrong way so it's blank
beerbohm
Page 2 of 3
custom
6 string guitars vs 7 string guitars for detuning
what is the difference between the les Paul custom and the les Paul studio custom
bc rich custom shop vs jackson custom shop
difference between 25" scale guitars and 27" scale guitars
Hollow-body Les Paul
jipajapa
08:09 PM
Semi hollow body?
tomkatzz
04:01 PM
New guitar.... hollow body
Donovan
10:42 PM
ooold ibanez hollow body
Robot Boy
12:29 PM
PGM 30..is it a semi hollow body?
mulletman80
11:28 PM
09:09 AM
