Old 12-03-2005, 07:44 PM
Dee  is offline
Posts: 8,514  -  iTrader: (2)
Horrible Fret Rattle!
Wassup.
I recently started to restore an old RG750 that was slightly damaged when the guitar was stored in a damp place. The case kinda rotted away a little and my old axe got rusted up pretty bad. Anyway, it's almost back to normal now, quite nicely playable, pickups replaced with some green PAF Pro's I found on *the site we're not allowed to mention*, the neck is still straight (amazing how these things hold up so well), but there's some evil fret rattle down the bottom of the board (headstock end), and I can't seem to cure it.
Should I shim the neck? If so, which siide -- body or neck side? There was a shim originally, but I forget where it was placed in the neck socket.Thanks for any help.
Old 12-03-2005, 08:08 PM
ryanb  is offline
Posts: 1,457  -  iTrader: (0)
Re: Horrible Fret Rattle!
I don't see any way a neck shim could help your problem. Possibly a nut shim, but only if it's necessary. Check out the frets in that area. They may have become loose or lifted from the dampness. A good setup should fix it.
Old 12-04-2005, 09:20 AM
beyblade  is offline
Posts: 237  -  iTrader: (0)
or....the truss rod is done up too tight.
neck shim, nut shim, paf pro, truss rod
Yet another poorly mixed song by your truly IbanezroadstarII Multimedia: Music, Pictures & Sounds 33 03-16-2006 10:01 PM
weird buzzing problem at one fret. evolusean Tech: Setup, Repairs and Mods 2 11-17-2005 03:45 AM
Horrible 1st fret buzz on RG7621!! Help! Jupiter Tech: Setup, Repairs and Mods 8 02-05-2004 10:30 PM
Fret Buzz from frets 11-14...? Drew Tech: Setup, Repairs and Mods 8 02-18-2003 12:02 PM
Fret Dressing How To - Not for the weak of stomach Kyle Odom Tech: Setup, Repairs and Mods 6 08-23-2001 05:06 PM
