Tech: Setup, Repairs and Mods
How do I adjust the action on Edge Pro?
10-02-2009, 12:29 AM
joeybadoey
Posts: 4 - iTrader: (
Hey there,
How do I adjust the action on my RG1570 Edge Pro? I tried inserting the tool that came with it, but it's not turning.
From what I understand I have to buy a set of allen wrenches to unscrew the tiny screw within the stud (or whatever it's called), and then I will be able to insert the key that came with it and raise and lower the tremolo?
Thank you,
Joey
joeybadoey
Find all posts by joeybadoey
10-02-2009, 11:39 AM
nuno
Posts: 4,725 - iTrader: (
Re: How do I adjust the action on Edge Pro?
joeybadoey
...to unscrew the tiny screw within the stud...
that's on the Edge, LoPro Edge and EdgeZero, not on the EdgePro. you just want to use a 3mm allen key.
nuno
Visit nuno's homepage!
Find all posts by nuno
10-02-2009, 01:53 PM
joeybadoey
Interesting....so I should just push harder to turn it?
Because I pushed pretty hard, but maybe not hard enough.
joeybadoey
10-02-2009, 02:23 PM
jb4674
Posts: 4,010 - iTrader: (
Reviews: 6
Are you trying to lower the action? Can you post a pic of your stud?
Jimmy
jb4674
Find all posts by jb4674
10-02-2009, 04:33 PM
eviltwin
Posts: 1,629 - iTrader: (
it should just turn, provided it didn't get the stud mod...
eviltwin
Find all posts by eviltwin
10-02-2009, 05:19 PM
smooth55
Posts: 1,010 - iTrader: (
Reviews: 59
Sounds like it's either at the bottom of it's hole or it has the stud mod. If you think it's got a locking stud, then yeah, you'll need to get a smaller allen wrench to get in there and loosen that. If you think it's at the bottom of the hole, shim the neck. Check out
www.ibanezrules.com
Look at the tech stuff to see what you need, it's a great resource.
smooth55
Find all posts by smooth55
10-02-2009, 10:08 PM
joeybadoey
Okay well shoot, I don't have access to a camera at the moment, but I'll fill you guys in on the details.
It's brand new, 2008 model and so it doesn't have the locking stud mod (but I did purchase that mod from Ibanezrules.com the other day lol)
This is my first tremolo, so I'm learning all about it. I used the key that came with it (the same one used to unscrew the locks at the nut), but it's so tiny that I can't get a grip. When I get the proper allen key, that might do the trick.
Which makes me wonder if it should be easy to unscrew those screws and lift and lower the edge tremolo? Again, maybe it's just the allen key.
Also, the tremolo was raised way too high, so I tightened the springs and got that sorted out, and that's when the strings lowered at bit and started buzzing. I tried loosening the truss rod quite a bit since it was buzzing at around the 5th fret mostly, but that didn't do much.
So that's why I'm trying to higher the action, although even if I do, the action is going to be pretty damn high, so I'm not sure what to do about that?
Thanks,
Joey
joeybadoey
10-02-2009, 11:03 PM
Magical Muffin
Posts: 536 - iTrader: (
You might see this as a cop-out solution, but I'd personally find some professional guy to set up your guitar better, maybe wait for the mod to arrive so you can get a 2 in 1. He might find some problem with the guitar that is hard to notice.
Magical Muffin
Find all posts by Magical Muffin
10-03-2009, 05:41 AM
eviltwin
I don't agree. This all just basic set up stuff, the keys come with most guitars for a reason. Any guitarist should know how to restring, adjust action, srpings trussrod etc. You wouldn't be able to go from 9s to 10s, or use alternative tunings with a floating bridge if you didn't know how.
@Joey, you wouldn't adjust the trussrod with the allen key you use for the locking nut woud you? so why would you try that on the bridge? They're definitely not the same size
The exact sizes are given in the manual.
eviltwin
10-03-2009, 11:49 AM
Ayrton
Posts: 4,157 - iTrader: (
44
Joey, everyone has to start somewhere, and I suggest you start here.
Rich has written some excellent articles on how to take care of your guitar.
Ayrton
Find all posts by Ayrton
10-03-2009, 07:38 PM
chlamy
Posts: 283 - iTrader: (
BTW, if you got it from Rich at IbanezRules, chances are it has the locking stud mod, as I recall it is included for all Edge Pro guitars in the packages, unless you specifically ask for it not being done (and save a, IMHO stupid, 35 dollars if I remember correctly).
Never try to turn a wrench to hard ... chances are it is just locked down so unlock it first with the small allen key before you use the big one to adjust the action.
chlamy
Find all posts by chlamy
how to adjust a truss rod on an ec-1000
how to set action on a Edge Zero Bridge
is my edge trem bar in all the way
Trying to adjust action
kelmaur
01:00 AM
Truss rod adjust/ action on USEW Custom
Severinsteelsmith
11:16 PM
How to adjust action of RG321
sikheadzraf
12:04 PM
How do i adjust intonation or action?
themaidenmaniac
09:32 PM
What to adjust for better action?
Jupiter
10:01 PM
01:59 AM
