Tech: Setup, Repairs and Mods
How Do you Store A Neck Without Strings?
08-16-2002, 01:48 AM
CrossingStar
Posts: 1,046 - iTrader: (
I just got this RG neck off of eBay and I won't be putting it on a guitar for awhile, so no
string tension
. Am I supposed to leave the
truss rod
completely loose or have it tightened a bit?
CrossingStar
Find all posts by CrossingStar
08-16-2002, 06:53 AM
sniperfrommars1
Posts: 3,302 - iTrader: (
leave it loose that will take all the tension off the neck. It would be a good idea while you have the neck off to polish the frets and give the neck a nice coat of lemon oil when your done too. Smooths everything up, although lemon oil seems to make the frets corrode a little bit, it will keep the neck from overdrying.
sniperfrommars1
Find all posts by sniperfrommars1
08-16-2002, 05:35 PM
CrossingStar
Yeah, I'm going to go to town and polish up the frets and clean the gunk next to the frets, I don't now what that stuff is. Built up dirt.
CrossingStar
08-16-2002, 10:33 PM
RSVampire
Posts: 1,813 - iTrader: (
don't clean too close. Some might be glue to hold the frets down.
RSVampire
Visit RSVampire's homepage!
Find all posts by RSVampire
08-17-2002, 12:18 AM
CrossingStar
True! I'll probably just scrape it off lightly with a pick. I'm still wondering how I should store though!
CrossingStar
08-17-2002, 04:19 AM
kirk
Posts: 1,554 - iTrader: (
Xing Cztarre
I am interested in knowing too. If you take all of the tension off the neck by loosening the truss rod, wouldn't that increase the odds of the wood twisting?
kirk
Find all posts by kirk
08-17-2002, 10:21 PM
sniperfrommars1
The wood usually twist because the adverse effect from the truss rod tension, it usually just bows alot when you release this tension from the neck. What Ive noticed is fatal backbow almost always comes from the strings being removed all at once for a period of time with tension on the trussrod.
sniperfrommars1
08-18-2002, 07:25 AM
CrossingStar
I emailed Warmoth to find out once and for all. "loose", said Ken Warmoth. So now we know.
CrossingStar
08-18-2002, 07:28 AM
CrossingStar
You know, "sniperfrommars1", you answered the question correctly TWICE and I didn't pay any attention. Sorry about that!
CrossingStar
08-19-2002, 06:11 AM
Scott 74
Posts: 1,293 - iTrader: (
I just make sure it's loose and my fretboard is straight(no backbow or frontbow).
Scott 74
Find all posts by Scott 74
08-20-2002, 04:59 PM
GhesQi J
Posts: 221 - iTrader: (
I'd go also with that (set loose)
The truss rod is designed to counteract the forces caused by the strings. But with no strings attached.. no force to be counteracted..
Cheers,
Joten
GhesQi J
Visit GhesQi J's homepage!
Find all posts by GhesQi J
string tension
truss rod
which way should the strings go
what guitar strings do the pros use
parker are they neck thru
what kind of strings does korn use
how do you put the strings closer to the neck on a ZR tremalo
07:34 AM
