Old 08-13-2005, 11:47 PM
carlos grijalva  is offline
Posts: 1,183  -  iTrader: (0)
How Does Weather affect your guitar?
I wanna know what are the damages that can happen to you guitar because of the weather, i heard that humidity damages the wood, what about hot or cold is there anything else?
Old 08-13-2005, 11:59 PM
CrossingStar  is offline
Posts: 1,046  -  iTrader: (1)
Re: How Does Weather affect your guitar?
This is probably in the wrong section but, humidity might damage an unfinished wood but normally no. Just changes the bow a bit from low to high humidity which is rectified by adjusting the truss rod in the neck.
Old 08-15-2005, 06:44 AM
Bezial  is offline
Posts: 540  -  iTrader: (0)
solid body should be ok . i had a classical that went through a really cold winter with me and the finish cracked on the front and sides, i guess that was due to the wood shrinking or whatever the cold does?
also i cant get it over to Australia from the uk as i think the flight would kill it (its handmade and very sensitive)
i know when winter hits here all i have to do is a little adgustment on the truss rods usually and again the same in summer.
Old 08-15-2005, 09:45 AM
Distantshore  is offline
Posts: 3,671  -  iTrader: (0)
Images: 4
Happens quite often here in FL!
Old 08-15-2005, 10:43 AM
GTR-MAN  is offline
Posts: 1,056  -  iTrader: (0)
Images: 8
Too dry and your neck can warp, your finish can crack. Too humid your neck can warp too. Heat is a factor too, can add to warpage and lossen glued joints etc. Toocold can make things crack too. I'm sure somebody know's more than I do about this. Just treat your guitar like you would a child, and you'll be fine. If you'd be uncomfortable, it's probably bad for your guitar too.
Old 08-15-2005, 10:45 AM
JJEMMER777  is offline
Posts: 8,374  -  iTrader: (5)
Yup
Old 09-06-2005, 06:01 PM
guitarshredder7  is offline
Posts: 610  -  iTrader: (0)
it makes **** warp
truss rod, truss rods
Why is Steve Vai's Prototype DNA in a guitar store window? - moochie777 JEM and Universe Guitars 21 06-04-2010 02:39 AM
My New Chrome Guitar (Yamaha Pacifica) cakewalkr7 Other 6-string Guitars (non-Ibanez brand) 25 05-01-2009 07:16 PM
Guitar Wood? Screaming Wind Tech: Setup, Repairs and Mods 50 02-26-2004 06:39 PM
Any classical guitar gurus out there? looking for appraisal Willin Other 6-string Guitars (non-Ibanez brand) 4 09-17-2002 07:55 PM
Time for a new guitar - A player is needed Anonymous JEM and Universe Guitars 5 12-20-2000 12:25 PM
