Old 05-31-2005, 11:47 AM
SwirlJem  is offline
Posts: 89  -  iTrader: (3)
How many springs???
Ok, so I'm gonna experiment with low tuning a 6 string. Anybody have any idea how many springs I'd wanna use to get the float right if I'm stringing with 13-56 and tuning B-B. May experiment a bit with drop A like this as well.
Thanks
Old 05-31-2005, 12:15 PM
rgr  is offline
Posts: 1,791  -  iTrader: (9)
Re: How many springs???
3 should work fine, you'll just have to adjust the tension (the 2 screws holding the claw to the body). If you try to tune to standard with that heavy guage, you'll probably need to add a spring and tighten the truss rod, and still may have problems if it's an Ibanez, not sure their thin necks will like that much tension, but you should be fine tuned down to B or A.
Old 05-31-2005, 12:53 PM
Jem7RB MK  is offline
Posts: 2,341  -  iTrader: (20)
3 is all ya need, had 11's on a UV with 3 springs, and my old Purple Jem had 12's on drop D for a time, Just screw the claw in, if you need to add an extra spring, your springs are worn, just get some new ones
Rob
Old 05-31-2005, 01:52 PM
SwirlJem  is offline
Thanks guys
truss rod
The Trem springs on my Jem 7VWH look Weird?? robbiedp Tech: Setup, Repairs and Mods 1 03-20-2005 08:45 PM
Anyone here using 3 52mm springs in V config /|\ ? Dr Mindcrime Tech: Setup, Repairs and Mods 1 09-27-2004 10:39 PM
Trem springs on 7vwh wont hold 10s... red5 JEM and Universe Guitars 10 03-16-2004 11:21 PM
Offset 4 springs dex Tech: Setup, Repairs and Mods 1 02-17-2004 07:41 AM
JEM 7DBK - why 4 trem springs? pseudomarine Tech: Setup, Repairs and Mods 1 02-20-2003 09:31 AM
